Originally posted by satdaveuk
Like you say, modifications can have a tendency to take away rather than enhance the performance and characteristics of the original.
The biggest diversion made with Goldscan builds, so far, has been the addition of the two resistors at identical spots in the two separate channels. This was because of complaints by builders, that the machine had a tendency to drift. And this is what completely changes the nature of the machine, as originally traced by Alexismex.
At first glance the opamp circuit driving the two J113's, is used to quickly reset the machine when large signals are detected. But when trawling the internet I came across VCR's. Was that particular pair of J113's intended to have a dual purpose of both quickly resetting and/or maintaining stability. By providing some kind of feedback driven voltage controlled resistance for bleeding to ground ?
Jose' did report getting a marked increase in sensitivity when he altered the value of the resistor that follows after the opamp that controls those two particular fets.
It would be nice to hear feedback on how others think it should operate.
As to original or modified...... your example of ivconics TGSL is great.
Construction of a clone Goldscan would be best left for accomplished and competent builders, as correctly adjusting the setup could prove tortuous for the novice.
Whereas, a modified version could be easier to construct and setup. And could quite likely (if done right), be better performing and simpler to use.
I'm glad that some interest is being generated.
