Whites classic ID schematic
  • Whites classic ID schematic
    Hi my friends,, I believe that I have something for you..
    This is schematic of White classic Id .,,,,,I wish you a lot of success with this detector
    Pcb
    I have something more for you this is a board of id,,this pcb is in SMD technology,,,size of resistors and capacitators is 1206
    dimension of board is
    x=8.5cm
    y=8.5cm
      thank you
      thank you friend
      i hope that this share will bring good succes
      but
      i have got other whites shematic maybe it can be orginal
      [email protected]
        thank you
        thank you friend
        but
        [email protected]
          What is the Best Gold Detector with high Depth ?
          hi all :
          I have found that most metal detectors in the markets were disappointing !even with new tech. they are using .
          Most M.D have depths limitations and can`t go deep more than (12 inches) !
          Carl , will you be able sure about one metal/gold detector that reaches 6 - 8 meter depth with accuracy signal ?
          P.S : I am not looking or even searching for low value items , i mean :
          coins, relics, nickels, or even gold nuggets !
          My whole work depends on : Lost Ancient Treasure , Buried Gold . i must tell evey one :
          I am working to locate big gold treasures ( more than 10 kg ) .
          Thanks 4 help ....
            Hi Ismail ,,you have schematic of classic or some else white's Md,,can you post that schematic or send me to my mail
              yes certainly but now i am soldiering
              i hope that i will send it as a mounth
              please write me your mail or msn adress or add me
              [email protected]
