I want ask Sasho, What is the voltage (P-P), at the point? and why do you prefer this type of oscillator? What is special about it?
SBG-TR Metaldetector
Don't worry, we're all in this together.Originally posted by scs-bg View PostI've wasted a lot of time making detectors as a hobby and I haven't gotten rich from it. It's a good thing I've always been at a high level in industrial electronics.
The important thing is to keep the hobby alive.
Stay alive and healthy.
XX years ago when I first saw that schematic; I immediately made that detector.
I used a cardboard tube and cardboard bodies for the coils.
The detector worked immediately from the first and without any problems.
But after that I lost further interest, life often brings some unpredictable things that disrupt plans.
I have very little memory of the details.
I only remember one detail; audio, it should be improved a bit.
Some slightly more complicated VCO would do a better job there.
If you made this circuit board, at what frequency and what results did you achieve in the ground, for example, for a can of Coca-Cola?Originally posted by Aziz View PostHi all,
increase the capacitor value of C5 from 270 nF to 1µ and you get more power to the TX coil. The TX coil voltage should rise too.
But I would replace the transistors T1, T2 (BC107) with BC337-40 for more bang.
I like the LC-oscillator.
Hi Algan,
I didn't make the circuit board. I have simulated the transmitter circuit with LTspice only. I haven't seen such an LC oscillator yet and I was interested in the working principle.Originally posted by algan View Post
The LC oscillator is working fine. It draws less current (power efficient).
