Originally posted by vesko666
Deep-searching R-TR metal detector schematic.
Hello Eclipse.
I wanted to build this project, but I lack the details of the coils. You can help me?
I need the diameter of the wire, the number of turns and the exact measurements of the coils.
I would like to build this project because I have seen the video and I liked it a lot.
Greetings.
Coil measures 5500uH - you can see that on my revision. I'm using thicker wire than the original details (0.56mm in diameter), I think you'll be fine with 0.3mm-0.7mm wire.
If you have LCR meter you can wind rough estimate of the windings are reduce the number if it's too high. I'm using larger sized coils and don't recall exact number of windings as I've made them 6 months ago.
Hello. Please tell us more about the operation of the device, its stability, the range of detection of targets in the ground, etc. Do you have a video of his work? Thank you.Originally posted by eclipse View PostCoil measures 5500uH - you can see that on my revision. I'm using thicker wire than the original details (0.56mm in diameter), I think you'll be fine with 0.3mm-0.7mm wire.
Artyom, I haven't made it yet. And it won't be ready anytime soon due to complex mechanical construction.
I did test some part of the schematic, which worked fine. I noticed that if you don't connect the TX coil and you turn it on - the 2 TX transistors overheat (kind of a design drawback), so you need to make sure you have TX coil connected at all times.
Note: The 78L05 regulator in the schematic there is wrong - I'll be using TLE2426 rail splitter.
Yes that will work nice (instead of the TLE there in my revision).
However I think that it can be improved (see capacitor connection C6/C5 change).
