Thanks,
IVCONIC!
Pulse IB discriminator (by Sasho - Varna)
Guest replied
Corrected PCB (8x8cm), one jumper (+ for NE5534)Attached Files
"This part.." is multi turn trimmer potentiometer....may be replaced with ordinary....
29xx can be replaced with 7808....although better to use low-drop..
NE5534 can be replaced with LF357 or LF356....I used those instead NE5534 and those working very well...also other replacements....LM318 for example...
regards!
Hello
Can you tell me can I change NE5534 whit something?
Because I cant find it!
What is Im2930-8?
And how are called this parts?Attached Files
HUH
Hi to all.
I completely forgot about this thread...
Yes the circuit works well. I just tried to run it with dead battery..
Now it works very stable - with perfect disc... just the range is somewhat shorty -> I have to make better coil as the one I tested the circuit..
Thanks to Sasho for this...
I will correct the PCB layout (one sided) and post it here.
Ivconic nice work as always
Guest repliedTo IVCONIC
HI,
can you make a PCB layout fot Metal detector with meter discriminating from Sasho Varna BG?
I have tryed,but I cant do this job!
I will be very greateful!!!
Guest repliedTo Ivconic
Change c13 to 47nf and c10 to 470 nf. Work better.
Regards.
Mixed up...
I mixed up photos here...never mind....Also didnt take any photo of RH pcb.... If anybody interested i'll do...
RIP
Relic Hawk is now resting in piece....Amen!
I still have complete pcb with components, nothing missing.I just gave up of fixing it. It is available for trading if somebody interested. I cant send it by mail, abroad....So only compatriots can make offers....Also bulgarians, due they are close to my place...
Heh!Heh!
Heh! When man has nothing smarter to do than he is fooling arround!?
So i took housing from my broken Relic Hawk and decided to put Sasho's detector inside, also to use R.Hawk coil with it. And it is working just fine with it. Detecting onluy coloured metals, very good.
Cola can it can detect with this coil at 90cm.....No detection on iron at all.
Heh!
Here's some photos!
P.S.
I made two detectors, one for me to play with it occasionally and one for my friend....
to Sasho-bg
Hello,
Well done man!
I ask you to help me because I am NEW.And nothing,BUT you post here PCB layout where the man can and do it himself!
You have a logic.
Guest repliedTo Geo
Gain 100-500 leads to strong ground effect.
Guest replied
Yes i have DXP...can import files from older versions...
I also have pcb for Eldorado, 2 sided, 2 pcbs,kind of splitted design...Is this you have? No need to send if it is the same...
regards!
