Originally posted by Geto
Some people will draw an opamp with the - (inverting) terminal at the top and the + (noniverting) terminal at the bottom. Others like it the other way around. You just need to be careful when you build the design, and note the correct connections. This can often lead to mistakes, especially when the two are mixed together in the same schematic, which is not good practice.
In other words, just make certain that you connect the inverting terminal to pin 2 and the noninverting to pin3. Essentially it makes no difference which method you use.
It looks like this detector requires a 50-0-50 uA meter, but Sasho should be able to confirm this.
