Full m/lab SD2000 schematics
  • Anis
    Originally posted by Andrei View Post
    Hi Anis! Good luck! I think to buy a ready-made coil, and if everything works correctly, then reel your coil
    Hi Andrei, hope you're doing well and in good health same to all forum members.
    I was certains that I will be back to you again:
    I received recently the litz wires and I build one 18" with a R= 0.6ohm and L=310uH.
    Checking it the SD2000 do note sound like what you have already posted.
    Checking the type of components you are using I found these:
    - capacitors used in the front ed receive, I didn't found them in the original schematic.
Name:	Front end receive.jpg
    Please can you detail the characteristics and what purpose for them?
    Also I see you connected 3 wires as below pic it seems to be the coil connector, If yes, please can clarify from an where these wire are connected since in the zed schematic there is only two wires connected with the coil?
Name:	Coil connection.jpg
    Your advices are much-needed
    Rgds
    Anis
  • Andrei
    Hi! Detech sef 11 mono vs minelab 11 monoloop? Detech 100 evro, minelab 200 evro
  • liekwang
    Originally posted by ZED View Post
    Nop ! not that i know off.
    ok mister zed then i will design the fcb layout in several parts if i have any questions please help mister
  • ZED
    Originally posted by liekwang View Post
    teacher does anyone have a good and correct fcb layout without any errors. and it's been tested thank you
  • liekwang
  • GoldenKiwi
    Many thanks for taking the time to work this through to explain it!
  • Carl-NC
    Wow, that's a really good app note. Ree is the ohmic resistance of the emitter and adds to the ac impedance of the emitter. So in my last post, "everything in the emitter" is actually (re + Ree) = 6.9+0.4 = 7.3 ohms. So the gain reduces to 1350/7.3 = 185. There are other terms I'm ignoring: Rbb/beta, Rs/beta, and ro. So maybe the actual gain is 180. Close enough.
    This gain is part of the open loop gain. The total open loop gain AOL is the gain of the diffpair times the open loop gain of the opamp (which is about 100,000) because they are both inside the feedback loop. So the total AOL = 185*100,000 = 18,500,000. But feedback reduces this to (1 + R118/R119) = 46 or so.
  • GoldenKiwi
    Q13 and R112 are not directly part of the gain. They are the current source for the diffpair; the collector current of Q13 is (5 - 0.75)/560 = 7.59mA. Let's call it 7.5mA. This current gets split in half in the LM394 diffpair so each leg sees 3.75mA, and that is the current through the collector resistors, which is 1.35k each side. Thus the DC outputs are sitting at about 0V.
    The gain of the diffpair is "everything in the collector divided by everything in the emitter." The collector side is easy, it's just 1.35k. The emitter side has no physical resistors, just the impedance of the emitter junction itself. That is called "re" and is VT/I where VT is the thermal voltage kT/q and I is the DC current. We know I -- it is 3.75mA -- and VT is 26mV at room temp. Therefore re = 26mV/3.75mA = 6.9 ohms. So the overall gain of the first stage is 1350/6.9 = 195. It is fully differential.
    Hi Carl, Many thanks! Apologies for the delayed reply, it took me a while to find the schematic version with components numbered, then follow along with your explanation and maths.
    I note that the App note AN-222 reference by waltr above mentions on page 5 that the Ree of the LM194 is 0.4R. Does this change the calculation or is this value of 0.4R Ree insignificant and we are talking about the effective in circuit value due to the constant current formed by Q13?
    Is the resultant gain of the compound LM394 Diff Pair + NE5534 = 195 * (1000/22) = ~ 8863 ?
    Still waiting for my SD2000 to arrive!
  • liekwang
    ok I have begun to understand what's in the scheme thank you sir for the quick reply
  • 6666
    [ATTACH]50832[/ATTACH]
    how can this land symbol be accessed by the scheme sent by zed and kt instead of this positive path batrai
    What they are drawing is the positive plate of the battery is ground, where you see the ground symbol all those points are connected together on the PCB, also to make drawing the schematic easier and to reduce the amount of lines they connect the component pins to the ground symbol.
  • waltr
    [ATTACH]50842[/ATTACH]
    I do not understand what type of capacitor symbol is used and why there is a GND logo on the negative battery bar that I circled
    The 'plus' symbol on the cap indicates a polarized cap, typically either electrolytic or tantalum.
    the "GRND" Name is a local 'ground' reference for the circuits on that page.
  • liekwang
  • liekwang
  • liekwang
    [QUOTE=Carl-NC;271306]Yes, should work fine.[/QUOTE
    OK
    Thank you for the info.
  • Carl-NC
    what is the BAS16 diode replacement can I use diode 4148
