I have Famous and Trails metal detctor, like the one show below.
Today i opend it and i tried to perform some mods has is show on a Russian forum.
The translation wasn´t perfect and here i m posting what i got:
That has made at once after forum studying: 1. - In the transmitter has reduced R8 about 4.7 clod to 2.7 clod. The amplitude of a signal on the coil has increased about 4 volt to 11 volt, it is possible and more but the sinusoid form is strongly deformed. 2. - In the receiver has taken a bite absolutely the resistor parallel to the coil - R7, 220 ohm. 3. - included consistently with regulator SENSITIVITY face value nearby 22 clod has replaced the resistor with 470 clod. 4. - has disassembled the coil (And it has been stuck together very qualitatively!) The hair dryer has warmed up thermoglue which the reception coil is fixed and moving it has tried to balance. To supervise a signal on condenser S10, in my case разбаланс has reduced about 4 volt to 0.3 volt. It is possible to reduce in "0", but it is necessary to clean old glue and to fix the coil anew
From this what i understood is the following:
1.- To replace R8, 4.7K with 2.7K. This was the easy part, no problem.
2.- I can´t find R7. Im also not shure if i have to replace the R7 value or i should place a 220 ohms btw the RX leads of the coil.
3.- Has i understood, i had to replace resistor of 22K with 470K. This resistor is very close to sensitivity pot. I also had done this.
4.- Finally i read something about the coil, but i m not very shure what to do here.
The test with this two mods, show very poor sensitivity and also i had to keep push the auto tune switch to enable the meter to go to the center.
I know this two mods are ok, but i had missed poninst 2 and 4 of the presents post.
So, i request from you people that speaks Russian, if you can help to translate the instructions to perform the full mod of the detector show below. Here is the text from the Russian web site:
Sorry for my english and i hope you can understand me.
Nelson
Металлодетектор MD-3006ss
- В мая этого года мне попался металлодетектор MD-3006ss, предположительно Китайской сборки. Как водиться в наше время, инструкции к прибору я не обнаружил и мне пришлось изрядно потрудиться, что бы выудить хоть какую то информацию из интернета.
Из форумов и сайтов любителей подобной техники и металлопоиска,я понял,что вся линейка выпускаемой китайцами техники за серией "MD" имеет очень низкое качество сборки и весьма посредственные параметры, которые ни в какой мере не могут сравниться с брендовыми моделями детекторов, таких как Garret,Minilab и им подобным. Однако должен справедливо подметить, что и цена брендовых производителей разнится в десятки раз.Весь вопрос в том, под что "заточен" прибор и для каких целей он будет применяться.Тут так же верна извечная формула "цена + качество = возможности прибора". Приобретя металлоискатель за условно 100 у.е.,трудно и наверно даже нелепо ожидать от него того же, на что способен прибор стоимостью в 1000 у.е. или даже прилично собранный самодельный прибор по хорошо отработанной схеме.
Учитывая,что не все имеют опыт и познания в радиотехнике,а так же навыки самостоятельного изготовления подобной техники,я решил на этой страничке опубликовать схему и фотографии этого недорого прибора и наиболее простые варианты его модификации которые улучшат его работу.
Краткое описание прибора и его настройка
- Питание прибора осуществляеться от трех батерей "Крона",где две батерии включены
последовательно друг с другом образуя напряжение 18 вольт.Третья батерея питает (независемо) аудиовыход прибора. Ток потребления (в моём приборе) оказался примерно 22 ма по питанию 18 вольт и по источнику 9 вольт от 15-35ма (зависит от регулятора громкости).
На передней панели прибора имееться переключатель контроля питания B1-B2.Запаса свежих батарей хватает на 20-24 часов непрерывной работы.
"НАЛАДКА СТРЕЛОЧНОГО ИНДИКАТОРА".
Указатель через некоторое время может потерять "Нулевое положение". Для возврата используйте следующие шаги:
1. Установите Переключатель Power в положение OFF;
2. Используйте отвертку, пока указатель не выстроится в линию с «0».
НАУШНИКИ
Вы можете подключить наушники (в комплект не входят) к датчику так, чтобы Вы могли слушать конфиденциально. Использование наушников экономит заряд батареи и облегчает идентифицировать тонкий звук. Внутренний спикер детектора будет отключен, когда вы подключите наушники.
"КОНТРОЛЬНАЯ ПАНЕЛЬ"
Индикация в приборе стрелочная и светодиодная. Красный светодиод-черный металл,зеленый-цветной. Тоже самое и на панеле стрелочного прибора.
"Красная кнопка"
"Красная кнопка" на ручке - сброс стрелки в нулевое положение, ее необходимо нажимать после выставления потенциометров Sensitivity, Ground balance или "Discrimination" а также для принудительного скоростного возврата стрелки в нулевое положение для точности измерения.
Потенциометр "Tune"
Установка стрелки в нулевое положение при нажатой красной кнопке "АВТО ТЮН"
Потенциометр Ground Balance.(отстройка от грунта)
Регулирование отстройки от грунта (видит все металлы, но не чувствует минерализацию грунта вызывающую помехи).
Используем следующие шаги для настройки:
1. Держим катушку на расстоянии 60 см от земли;
2. Ставим потенциометр "Ground Balance" в среднее положение, нажимаем красную кнопку;
3. Опускаем катушку до расстояния 10 см;
4. В зависимости от отклонения стрелки подкручиваем потенциометр в ту или другую сторону;
5. Поднимаем катушку снова до 60 см;
6. Нажимаем красную кнопку и еще раз опускаем.
Добиваемся, чтобы при опускании катушки с 60 см до 10 см стрелка оставалась на нуле.
Потенциометр "Discrimination"
Discrimination - регулирование дискриминации (разделение на черный/цветной, черный - стрелка падает влево, цветной вправо). Например, для отстройки от пробки: ставим режим "дискриминация" слева направо крутим потенциометр "Discrimination", до положения при котором стрелка начинает падать влево. Отстраиваться необходимо последовательно:
1. Изменили положение потенциометра "Discrimination";
2. Нажали красную кнопку;
3. Провели пробку над катушкой 10-15см.
И так пока не получили результат - стрелка падает влево.
Потенциометр "Sensitivity"
"Sensitivity" – регулирование чувствительности, при максимальном положении потенциометра будет наибольшая глубина обнаружения прибором металлических объектов и наибольшее потребление питания.
ПРИНЦИП РАБОТЫ НА ПОИСК
При нажатии красной кнопки на ручке прибор запоминает текущее магнитное поле вокруг катушки с учетом положения потенциометров "Sensitivity" и в зависимости от режима потенциометра "Discrimination" или "Ground Balance", т.к. на разной высоте от земли разное магнитное поле, для достоверных результатов необходимо работать на высоте чуть меньшей той, на которой была нажата красная кнопка. Например, если кнопку нажали на высоте 10 см от земли, то работаем на высоте 7-10 см от земли не выше.
Ложный Сигнал
Ложный сигнал может появляться, если вы работаете на местности с сильным магнитным полем. Также если почва сильно минерализована.
Прибор для корректного тестирования нужно выполнять в поле,там где нет металличских предметов и наводок от сетевого оборудования.
Реальные возможности прибора!
После проверки выяснилось,что реальные возможности прибора MD-3006ss, не соответсвуют своим "паспортаным" данным,которые заявил изготовитель. Реально своим вариантом прибора мне удалось "увидеть по воздуху" следующие предметы:
Монета 5 коп.СССР (диам.25мм)- максимум 12см;
Крышка от кастрюли (диам.200мм) - 35см;
Стальная плита 400 на 400мм - макс.0.55м;
Далее,прибор уже не чувствует ничего вообще.
Недостатки!
Низкая чувствительность (до переделки прибора она в среднем состовляет 30-40см)!
Дискриминация очень плохая и работает в самом конце движка потенциометра.
(Едва-едва можно отсеять чугун от цветника).
Регулятор отстройки от грунта требует кропотливой настройки.
Во время поиска часто происходит сбивание настройки от прикосновения к поисковой
катушки ввиду её низкого качества. Отсутствует герметизация катушки!
Питание прибора расчитано на ТРИ отдельных батареи. Малый срок жизни батарей "Крона".
Отсутствует герметизация корпуса самого прибора!
Nelson
Originally posted by amtech2005
maybe??? Anyway check out the very close 'similarities" and best of luck............Eugene51
model with 3x9v batteries and very different to the 4001 with 6xaa's , 2 knobs , 1 button.
