“S”- tone discriminate metal detector.
  • scs
    This is motion discriminator for "first discriminating signal."Detector works well with DD search coil.Nот for inexperienced people.Make real good depth in the ground.
  • emoxristov
    Naeem
    can you upload a working board PCB and an explanation of the setting of the metal detector.
  • emoxristov
    Yes you are very right but the first coil curl and started the second cable end pretty stupid not figured dalzhinata.S OO coil works quite well.
  • Pompey
    If Tx=110w and Rx must be 110w.
  • emoxristov
    Here are my machine parameters dish 19 cm,TX-110 RX-90 0.29 mm wire. Upload photos and videos. Thank all who helped me on this project.
    Sorry for bad english
    http://prikachi.com/images.php?images/66/5548066q.jpg
    http://prikachi.com/images.php?images/68/5548068x.jpg
    http://prikachi.com/images.php?images/70/5548070s.jpg
    http://www.youtube.com/watch?v=MTtJz...ature=youtu.be
  • Qiaozhi
    Originally posted by Pompey View Post
    4 волта има спрямо виртуална земя. Напрежението се дели на две и от средната точка до + и - е по 4 волта
    It is ok to post in your own language as long as you also post an English translation.
    Not everyone here has access to a translator that can convert Bulgarian to English.
    Translation:
    4 volts to a virtual earth. Tension is divided into two and from the midpoint to + and - of 4 volts
  • Pompey
  • Macmbpa
    schematic
    На схемата където са дадени напреженията. За C31 и C28 как е възможно да има 4 волта, след като са свързани към 8 волтовото захранване?
    For C31 and C28 how is it possible to have 4 volts after being linked to the 8 volt power supply? google translate
  • mario
    capacitors
    Thanks for the heads up on the capacitor sizes/types. Can some one please verify these capacitors before I place them on order. I tried to follow porkluvr's guidance, but I would like for them to be verified anyways. If something goes wrong, It's going to be difficult debugging the capacitors! I used the Capacitor conversion chart at : http://www.justradios.com/uFnFpF.html
    22n (.022 uf) = 2 x Polyester Film Capacitor 100volts
    220uF = 3 x Aluminum Electrolytic 25 V , 10% Tolerance
    1000uF = 1 x Aluminum Electrolytic 25 V, 10% Tolerance
    47pF = 2 x Multilayer Ceramic Capacitor - Leaded 100volts 47pF 5%
    150nF (.15uF) = 3 x Polyester Film Capacitors 63V 5%
    470n (.47uF) = 2 x Polyester Film Capacitors 63V 5%
    220nF (0.22uF) = 2 x Polyester Film Capacitors 63volts 5%
    1uF (1.0uF) = 2 x Polyester Film Capacitors 63volts 5%
    1nF( 1000pF) = 4 x Polyester Film Capacitors 100volts 5%
    10nF ( .01uF) = 4 x Polyester Film Capacitors 63V 5%
    47nF (.047uF) = 1 x Polyester Film Capacitors 63V 5%
    100nF(.1uF) = 6 x Polyester Film Capacitors 63V 5%
    68nF ( .068uF) = 1 x Polyester Film Capacitors 100V 10%
    4.7nF (0.0047uF) = 1 x Polyester Film Capacitors 63volts 5%
  • porkluvr
    Originally posted by mario View Post
    Can some one give me the required voltages for the capacitors?
    You need to use a OO or DD coil. Each half should be about 4.6mH and that is very different from the coil you were talking about wanting to use.
    Use 16V or 25V electrolytic capacitors for the 220uF and 100uf.
    The non polarized capacitors can be 50V film with one exception: 50V would be OK for C5 but 63V might be better.
    For C1 (47pF) use 50V film or else 100V NPO/COG ceramic.
    C10 could be just about any 47pf unit.
    It is OK to use higher voltage capacitors than what I said, but the packages will be larger.
    Any 1N400x series diode should be OK for D11, D12.
  • Qiaozhi
    Originally posted by sevar12 View Post
    no this is C4
    Yes, you are correct. I was mislead by the asterisk next to C1 on the schematic, assuming this was the component that was being referred to.
  • mario
    Component List!
    Ok gentlemen, I got a component list of all the required items to make the shopping easier. Remember, I'm going by Naeem's revision. I noticed he made some minor changes to Sasho's 1.2 version. For instance, Naeem uses 7808 instead of LM2930-8, so he accommodated diode 4007. He also eliminated MPSA13, etc.
    Can some one give me the required voltages for the capacitors? No where are the voltages listed. For example, a 220u capacitor, is it 50V or 6.3V; or a 100n capacitor , is it 5V, 63V, 250V, or 400V?
    I think once I get the voltages down for the capacitors, I should be able to order all the components online and start assembling my board.
    Remember, this list of the parts used is a reference to make the shopping easier. I may have miscounted a few of the items (Kinda of hard staring at the screen for such a long time, sorry).
    Thanks,
    Capacitors
    22n 2
    150n 3
    470n 2
    47n 1
    47p 2
    220n 2
    1u 2
    1n 4
    10n 4
    100n 6
    68n 1
    4.7n 1
    220u 3
    1000u 1
    TRIMMER POTS
    20K 1
    100K 2
    Resistors
    22k 7
    4.7k 5
    10k 14
    2k 5
    47ohm 2
    47K 4
    220K 4
    220ohm 2
    100ohm 1
    100k 4
    1M 3
    10M 2
    33k 2
    1k 1
    6M8 1
    1k5 1
    680k 1
    470k 1
    15k 1
    2M 2
    3M 1
    27k 1
    TRANSISTORS
    BC556 1
    BC547 4
    BC517 1
    LM7808 1
    TIP127 1
    DIODES
    LN4007 1
    LN4148 10
    LN4001 0?? (2 according to schematic, on lay out file, LN4007 is used?)
    IC s
    NE5532 1
    TLO62 4
    LM393 1
    LM358 1
    4053 1
  • mario
    Thank you for clearing that up.
    How difficult would it be to adapt Minelab SD PI mono coils? I believe they have induction of 300 uH and resistance of .5 ohm.
    I'm going to try to make those coils compatible if you guys tell me there's not much more work involved. I could use Sasho's detector along with the Minelab coils in order to save on equipment space.
    Also, Sacho's design along with a 1 inch ferrite-core coil would make one awesome pin pointer!
  • sevar12
    sled kato nastroish bobinite v rezonans mahash C1 i podbirash C4 za maximalna amplituda na signala mislia che sasho go beshe kazal niakade vav foruma no ne se seshtam kade beshe
  • sevar12
    no this is C4
