I have had this old metal detector for at least 15 years. it says Garrett Speed King 2D Wide Scan on the side and there is a patent number on a tag Pat. # 3665522. The Patent seems to be for the coil and not the machine itself. what I need is a power supply, the battery tray is missing and I doubt I will find one so improvisation is in need. I need a wiring diagram. I can see at the back of hole where the tray belongs there is a connector with 5 or 6 prongs on it and that is as far as i have gone. I have been searching for someone or some direction before I take it apart. any help?
Wanted! for old Garrett Speed King
If you register, then you can post some images. This would help to identify the detector.Originally posted by Unregistered View PostI have had this old metal detector for at least 15 years. it says Garrett Speed King 2D Wide Scan on the side and there is a patent number on a tag Pat. # 3665522. The Patent seems to be for the coil and not the machine itself. what I need is a power supply, the battery tray is missing and I doubt I will find one so improvisation is in need. I need a wiring diagram. I can see at the back of hole where the tray belongs there is a connector with 5 or 6 prongs on it and that is as far as i have gone. I have been searching for someone or some direction before I take it apart. any help?
