aaaa
  • Orbit
    WWho is paranoid, I do not know. But I know that I came to 3 pieces and they had a problem, especially with the influence of the country and especially the drive mode. And it says the scheme that I have the drawing power pulse, and customers who had it handed to you one big lie. A detector that you put no connection with the aforementioned detector that you put the CZ 5th pulse power using the double pulse and minelab gp3500. And this is what you see using the probe 27cm dd and 38 dd probe in spades Piku has 500v and not used at all irfd as cz5 etc.. The detection probe has a range of 27cm ma 1 euro 43cm in the air with 38 cm probe tin 28cm to 25 times in the air 210cm coin 4cm to 38cm to 70cm probe scale, etc. He serves as an indicator of the impact of land dal properly set to rest any environment AA who is not well configured scale turns left or right.
  • aft_72005
    He made dozen of those before passed away.
    Also , I remember very good him . it is very bad news (pass away)and I am sadly heard.
    My depply condolence for jackdetect family.
    God bless jackdetect
  • peroon
    That is part of pcb from Classic III clone - not from "Pulse Power VLF".
  • Esteban
    Originally posted by peroon View Post
    Few local characters.
    Those were "local" until recently.
    Now i see those are appearing here too!?
    One of those already polluted local forums with his ignorance and got banned several times from all local forums.
    Second one just appeared here. Second one could be pretty descent guy if he was out of influence of first one - the main scum snout.
    First one took advantage from facts that second one is living in some small and rural village with no internet connections and no phone lines at all , up to recently . So first one was "the only connection" to second one with outer world.
    Second one is uneducated but very persistent enthusiast and during years he learned some md tricks. Now he is able to diy some of md projects. First one is taking those handmades and presents them to others as his own, although that snout is complete ignorant in electronics.
    So all that was pretty harmless until recently, as far as it was local.
    But now is bad to see same tendencies here on this forum, so i simply must did something. I posted here the real truth.
    Reding other topcs.....like SMW you can easilly locate who is the main snout and "first" who made all the damage.
    That first snout now invited the second one here on this forum to support his image.
    Esteban, despite argue and debate , you are intelligent man enough and you will easilly understand who is who here.
    Keep cool Esteban, don't be paranoid.
    Your name is last on my mind (keeping in mind that Jackdetect did share with you some infos - i know that, i was there with him at the time)
    Thanks very much. I wish to share message written by him in schematic (show only a part). Very special person!
  • peroon
    Do you can provide more names?
  • Esteban
    Good guy! Announcement on forum:
    http://www.geotech1.com/forums/showt...ght=jackdetect
  • Esteban
    Not from Montenegro but from Serbia, Aleksinac city (Tesica village 6km away).
    And this metal detector has nothing to do with PI's. It is VLF I/B.
    Was my closest friend and i've been there at the time when he introduced his first prototype. He made dozen of those before passed away.
    This VLF I/B was projected as close to genial design. I was delited with it's performances. It has minor lacks easilly fixable. Jackdetect realized that and wanted to fix those minor lacks in next serie. Pitty he didn't had a time enough.
    As his close friend i feel much offended when see some scum reptiles here taking advantage of his work.
    I do have documentation of all his work. But in respect to his personallity and direct wish of his familly i simply can not post those in public neither to share.
    Not only that; i simply do not intend to use whole design nor even a part of his works.
    This detector was completed as His own original design. Some of the principles are used from some Fisher solutions as model only.
  • Esteban
    Emails from Jackdetect to me:
    Hi Esteban,
    This is schematic of unknown Fisher, which working excellent. I was making lot of this. No big different in efficiency between him and 1266, but this detector is much simplest.
    I am locking for Prn with written component, in my chaotic lab.
    Are you understand connections on coil image, which I send to you? Less Rx (bucking) is connected in serial with big Tx, but on opposite direction. You need to find balance on this way:
    -Firs, you need detector which work (at last Tx and Rx part), and you must connect coil which you want to make balance. You must having a oscilloscope, and connect them on output of Rx OP amplifier. When coil is not balanced, you will see quadratic signal.
    -To find good balance, you must add or remove couple of turns on bucking coil (less Tx).
    -When you hit balance, sinusoidal signal on oscilloscope will go near zero (same balancing system like DD).
    - After balancing, you must change parallel condenser on Rx (to get 5Khz), and on Tx to get best resonant frequency ( most density on oscilloscope).
    -Then you must experiment, to find best ground and disc performances.
    I can help you about any problem on Vlf designs.
    Best regards,
    Jackdetect.
    Hi Esteban,
    I finally found Prn. Now you have complete information for work. Fisher 12xx working like1266, usually in disc mode. If you havent experience with Fisher system, you can find some original 1266, and see the system. Good luck.
    I will travel for 2days on Montenegro (Adriatic see), because need arrest. I have my house on Montenegro, but havent phone and PC (it is better for my eyes, and soul). I will back about 1.September. If you have questions, you have two days for my answers.
  • peroon
    Thanks for clarification! Yes, I remember that he wrote me about spare time in Montenegro... forgot this detail. Very decent person. I sorry his loss of this world. Their treatment was right toward the people...
    Yes, year before he died, he was in Montenegro on summer vacation, with his family.
  • peroon
    Agreement between me and Adrian was about to continue the project was not completed and had a lot of shortcomings in terms of the impact of the country and in a small range of disk mode, etc.. And that when completed is presented to the public so that finally got everything what are the requirements of a good detector. Just do not keep you ignorant of the famous masters of the Montenegrins. Just as I doubt that you are from Montenegro.
    "Not completed"???
    He already made and sold dozen units, how is possible to do that with "not completed" detector?
    Some of those detectors are still in wide use. Working extreme good. I tested it several times, i went to sites with it, i founded much items with it already. So?
    I will check with Adriana your claims soon.
    Also;
    your first post where you showed photos - i don't see you explaining which idea and product was that detector and how you got it? ( i know you exchanged it with other guy, detector was broken, had some minor fault at audio stage - common fault at those detectors).
    Also i don't see your explanation in your first post here - same explanation you gave now in your last post, pressed with facts i posted?
    All i see in your first post is " My detector..."!??
    I am not from Montenegro?
    Who told you that???
    You do not understand English well and now you mixed up everything!?
  • Orbit
  • Qiaozhi
    What was that??? "Eastserbian English"!??
    Despite your illiterate use of some online translator i think it is good enough to understand what you wanted to say.
    So you actually are saying that Jackdetect's design was very bad UNTIL you came on "scene" and fixed all the lacks and improved it?? And you had to change 50% of it to make it work!?!?
    Ha,ha,ha!
    Look dude, don't mix in things you are not able to hold.
    Do what ever you do but do not come here and talk nonsences and lies.
    This is the result from my translator, although some of it didn't translate proprly:
    Secondly this is what you see is only external appearance and in agreement with his wife and I took some of his ideas that just for this reason it is there are many shortcomings to be corrected and to finally reach your desired form and if you were a friend to call his wife, Zeljko Adrian and uvericeiete in it. Eiko wiseacre.
  • Esteban
  • peroon
    Drugo ovo sto vidite je samo spoljasnji izgled a u saglasnost sa njegovom suprugom sam i preuzeo neke njegove ideje da bi bas iz tog razloga sto je ima puno nedostataka da se to ispravi i da konacno dobije zeljenu formu pa ako ste bili prijatelj sa Zeljkom pozovite njegovu suprugu Adrijanu i uvericeiete se u to . postovane sveznalice.
    Write it on English.
    I will call Andirana to check your claims.
  • peroon
    In the preliminary design is djekdeta but this detector has no connection with these mild detector because I am 50 per cent had to edit that would finally get the detector that really worth the guys they all know that after cesar mentioned this could mean that some table were logged under two names and itri the geotechu and make that the brightest of all and put all their texts, and all are mixed and have not made a single detector in life.
    Ha,ha,ha!
