aaaa
    Thanks for clarification! Yes, I remember that he wrote me about spare time in Montenegro... forgot this detail. Very decent person. I sorry his loss of this world. Their treatment was right toward the people...
    Yes, year before he died, he was in Montenegro on summer vacation, with his family.
      Emails from Jackdetect to me:
      Hi Esteban,
      This is schematic of unknown Fisher, which working excellent. I was making lot of this. No big different in efficiency between him and 1266, but this detector is much simplest.
      I am locking for Prn with written component, in my chaotic lab.
      Are you understand connections on coil image, which I send to you? Less Rx (bucking) is connected in serial with big Tx, but on opposite direction. You need to find balance on this way:
      -Firs, you need detector which work (at last Tx and Rx part), and you must connect coil which you want to make balance. You must having a oscilloscope, and connect them on output of Rx OP amplifier. When coil is not balanced, you will see quadratic signal.
      -To find good balance, you must add or remove couple of turns on bucking coil (less Tx).
      -When you hit balance, sinusoidal signal on oscilloscope will go near zero (same balancing system like DD).
      - After balancing, you must change parallel condenser on Rx (to get 5Khz), and on Tx to get best resonant frequency ( most density on oscilloscope).
      -Then you must experiment, to find best ground and disc performances.
      I can help you about any problem on Vlf designs.
      Best regards,
      Jackdetect.
      Hi Esteban,
      I finally found Prn. Now you have complete information for work. Fisher 12xx working like1266, usually in disc mode. If you havent experience with Fisher system, you can find some original 1266, and see the system. Good luck.
      I will travel for 2days on Montenegro (Adriatic see), because need arrest. I have my house on Montenegro, but havent phone and PC (it is better for my eyes, and soul). I will back about 1.September. If you have questions, you have two days for my answers.
        Originally posted by peroon View Post
        Not from Montenegro but from Serbia, Aleksinac city (Tesica village 6km away).
        And this metal detector has nothing to do with PI's. It is VLF I/B.
        Was my closest friend and i've been there at the time when he introduced his first prototype. He made dozen of those before passed away.
        This VLF I/B was projected as close to genial design. I was delited with it's performances. It has minor lacks easilly fixable. Jackdetect realized that and wanted to fix those minor lacks in next serie. Pitty he didn't had a time enough.
        As his close friend i feel much offended when see some scum reptiles here taking advantage of his work.
        I do have documentation of all his work. But in respect to his personallity and direct wish of his familly i simply can not post those in public neither to share.
        Not only that; i simply do not intend to use whole design nor even a part of his works.
        This detector was completed as His own original design. Some of the principles are used from some Fisher solutions as model only.
        Do you can provide more names?
          Good guy! Announcement on forum:
          http://www.geotech1.com/forums/showt...ght=jackdetect
            Few local characters.
            Those were "local" until recently.
            Now i see those are appearing here too!?
            One of those already polluted local forums with his ignorance and got banned several times from all local forums.
            Second one just appeared here. Second one could be pretty descent guy if he was out of influence of first one - the main scum snout.
            First one took advantage from facts that second one is living in some small and rural village with no internet connections and no phone lines at all , up to recently . So first one was "the only connection" to second one with outer world.
            Second one is uneducated but very persistent enthusiast and during years he learned some md tricks. Now he is able to diy some of md projects. First one is taking those handmades and presents them to others as his own, although that snout is complete ignorant in electronics.
            So all that was pretty harmless until recently, as far as it was local.
            But now is bad to see same tendencies here on this forum, so i simply must did something. I posted here the real truth.
            Reding other topcs.....like SMW you can easilly locate who is the main snout and "first" who made all the damage.
            That first snout now invited the second one here on this forum to support his image.
            Esteban, despite argue and debate , you are intelligent man enough and you will easilly understand who is who here.
            Keep cool Esteban, don't be paranoid.
            Your name is last on my mind (keeping in mind that Jackdetect did share with you some infos - i know that, i was there with him at the time)
              Thanks very much. I wish to share message written by him in schematic (show only a part). Very special person!
                That is part of pcb from Classic III clone - not from "Pulse Power VLF".
                  Also , I remember very good him . it is very bad news (pass away)and I am sadly heard.
                  My depply condolence for jackdetect family.
                  God bless jackdetect
                    WWho is paranoid, I do not know. But I know that I came to 3 pieces and they had a problem, especially with the influence of the country and especially the drive mode. And it says the scheme that I have the drawing power pulse, and customers who had it handed to you one big lie. A detector that you put no connection with the aforementioned detector that you put the CZ 5th pulse power using the double pulse and minelab gp3500. And this is what you see using the probe 27cm dd and 38 dd probe in spades Piku has 500v and not used at all irfd as cz5 etc.. The detection probe has a range of 27cm ma 1 euro 43cm in the air with 38 cm probe tin 28cm to 25 times in the air 210cm coin 4cm to 38cm to 70cm probe scale, etc. He serves as an indicator of the impact of land dal properly set to rest any environment AA who is not well configured scale turns left or right.
                      discrimination left and right iron precious metals, and that the model of the cabbage was not, and if you saw how general these models did know that in the drive mode were terribly unstable on the ground that it was not possible in general use - what is cesar cesar concerned that I made for another when it is not known and sold at least 50 pieces. not be known until it is set us a friend on geotech, since sold. And when the model ispusio your post is better than him, will then come to the Internet. And that which can be seen next minelaba and extremes is bass the better, which destroys the country, and who has to pick pik 60V.
                        A platform well know English so I think this character a little further from Nis know where the brightest, but wakes up when something napametniji budes cleverly done and not to hate someone for some reason that you, the izdigo, that was you and no ITI except you.
                          Cesar I'm in some way mention the conversion serbijan most vanted, I gave dvozvucne bonding pattern of discrimination, but not anybody down, but I made him under the name Gold Rover, a scheme comes from my good friend Stanimir. And not from some who themselves proclaim the great masters of this forum and know who is who log on the forum who knows the names of Kolko writes Cesar because I was there wrote Gold Rover. And here you cesar in SMD. ha ha ha haha
                          Let me see.... you have there Jackdetect's handmade, you have there broken GP3500 .....and you heve there "Caesar" copy ....hmmm!?!?
                            cesar smd
                              Orbit...nemoj da vise koristis taj program za prevodjenje jer ne prevodi uopste kako treba. Ono sto "izlazi" na engleskom zaista nema nikakvog smisla. Tesko je i meni da protumacim sta si hteo da kazes a kako li je tek ostalima ovde na forumu?
                              Samo dzaba trosis vreme sa tim. Ako imas sta ozbiljno da kazes i zelis da to vide i razumeju svi na forumu onda napisi bre brale to na srpskom i ja cu ti prevesti ovde da svi razumeju.
                              Slusaj; meni nije cilj da te ismevam i da te diskreditujem ovde. Nije lepo i nije fer i naravno nije ljudski.
                              Taj detektor je Zeljkov intelektualni rad ali je sad u tvom vlasnistvu i niko ti ne moze braniti da po njemu prchkash i cackash koliko hoces, tvoja volja. Ali nemoj ovde da se pojavljujes i javno tvrdis kako je to tvoj licni intelektualni rad jer to nije istina. Zeljko je bio moj licni prijatelj ja se osecam jako lose kad vidim takvo ponasanje.
                              Ako si ista radio i modifikovao na tom detektoru onda mozes lepo napisati sta si radio i kako si ga unapredio, to ti niko ne brani. I mozes to objaviti kao tvoj licni dodatak na njegov vec zavresn projekat. I to ti niko ne brani. Ali bi bilo fer sa tvoje strane da u startu kazes da je to intelektualni rad njegov.
                              Mozes sve to napisati ali i ne moras. Niko te ne tera niti te moze naterati. Takodje da bi sve to zaista ostali mogli da procitaju i razumeju ti napisi i daj ovde a ja cu to prevesti na Engleski.
                              Ili ako neces da ja prevodim, nema frke, daj nekome ko to moze da uradi bez gresaka. Ali okani se vise tih programa prevodica jer to sto ispada iz njih ne lici ni na sta niti ima smisla.
                              Orbit don't use that translator any more because it is not translating properly at all. Results we can see here are without much of sence.
                              It is difficult even to me to understand your points, not to mention other people here.
                              You are wasting yout time with that (translator).
                              If you have something really interesting and serious to tell here and you want others to read and understand, than write that on serbian here and i will translate it for you (at least more properly than it is now).
                              Listen; it is not my goal to make fun of you here or to discredit you here. Not nice and not fair and not human.
                              That detector is Jacdetect's intelectual product, and now you own it, so nobody can stop you to do with it anything you want. It is up to your free will.
                              But DO NOT come here and claim it was "your" cose it is not.
                              If you really ever done anything on it; modded it, changed something, added something...than you can write here details ..or not, again it is up to your free will.
                              Again i could translate that to English.
                              If you don't want exactly me to help you in translation, no problem; ask somebody else who can do that properly.
                              But do not use those translator, you used so far, cose it gives funny translations, without much of sence.
                                Lose si ti sve to protumacio i skapirao brale. To sto ti sad ovde pricas niko ti od ovih sa foruma nece razumeti . Ali ja ipak ponesto razumem.
                                Stanimir je ok lik i ja ga cenim. Ali imas ti tu jos nekog "saptaca" i "savetodavca" koji ti puni glavu slicnim glupostima. Taj je najveci smrdljivac u zemlji Srbiji. Kako taj seje tako ce i poznjeti.
                                Nemoj da si naivan i da prihvatas sve za istinu sto cujes od ostalih.
                                Razmisljaj malo i svojom glavom.
                                Ti si dobio semu od Stanka. Stanko je dobio semu od ko zna koga i kada ali najpre ce biti da je dobio od Stilijana iz Bugarske. A tu je i Zoran iz Brusnika koji takodje pravi Cezare i u stvari Zoran je prvi i dao to ime tom detektoru.
                                A ja sam i semu i prvu verziju plocice dobio jako davno od jednog prijatelja iz istocne Bugarske, medju gomilom ostalih sema. Sve dok nisam video prvi "Cezar" rucni rad, koji je inace napravio Zoran iz Brusnika, ja dotle nisam ni hteo da pravim taj detektor. Imao sam i prece i bolje projekte pre toga.
                                Kada sam video tog Zoranovog Cezara shvatio sam da tu mozda ima potencijala. U medjuvremenu sam i sa Stankom poceo da saradjujem pa sam video da i on radi isto to (mada je on otisao najdalje od svih i dosta je toga unapredio i izmenio).
                                I tako je sve krenulo.
                                Niti Stanko niti Zoran nisu takvi losi karakteri da pricaju svasta i da ti pune glavu glupostima, naprotiv to su korektni likovi i to znam pouzdano. Ima tu jedno djubre iz okoline koje nema blage veze sa mozgom, ne raspoznaje niti otpornik od kondenzatora, ali zato ide svuda redom gde ga neznaju i prica kako je ekspert za detektore. Taj isti lik je i tebe iskoristavao vise puta a da ti to nisi znao.
                                Tvoj problem je sto si odsecen od sveta. Nemas telefon, nemas internet i ne cujes se sa ljudima. Bar je tako bilo do skora. Ako se to izmenilo i ako sada imas internet znaj da mi je jako drago zbog toga i da bih voleo da se cujem sa tobom preko nekog mesendzera. Samo reci kog i kako da te nadjem.
                                Dakle to djubre od coveka je tada zloupotrebljavalo to sto si odsecen od sveta i iskoristavalo tvoj rad i tvoju muku.
                                To se mene ne bi ticalo uopste da nisam i sam licno pogodjen takvim ponasanjem. Evo sad se pojavljujes ovde i pises razne aluzije na temu ovoga i onoga a ja u tim recima ne prepoznajem tebe i tvoje reci vec vidim i prepoznajem slicne price koje sam cuo od mnogih drugih koji su mi pricalii kako to djubre od coveka ide po Srbij i prica unaokolo.
                                Dakle tvoje je greska u tome sto slusas i verujes u nesto sto nije tacno. Umesto da si me kontaktirao i da kroz pricu sa mnom proveris sta je tacno a sta nije.
                                Ja se neznam licno sa Zoranom ali znam da je prilicno korektan covek. Znam se sa Stanimirom licno i znam da je odlican lik i kao covek i kao samograditelj detektora. Tebe znam povrsno ali sam cuo da si takodje korektan covek. Pa zasto onda svi mi da trpimo zulum jednog djubreta koje ide redom medju nama i pronosi lazne price koje nas samo jos vise svadjaju i onemogucuju ikakvu saradnju medju nama? Zar smo mi svi toliko glupi?
                                Zar nije pametnije da se druzimo i saradjujemo?
