Volksturm SM + GEB
  • Qiaozhi
    Originally posted by cristi71 View Post
    sorry Now I've seen(d 4066) geb=ground e.. balance?
    GEB = Ground Exclusion Balance
  • cristi71
  • cristi71
    do not understand ... There are several variants, S..SM .. what is GEB? WHERE IS CD 4066 ? thanks
  • mehdi
    good job And
    very nice
    mehdi
  • and
    All Files to revised
    pin 7 to negative, not to the ground. you have to get full amplitude for control of 4066 (or 4053 - if you use it). the chops' power supply has to have a level of op-amps' supply (equal or more). ie -E and +E in the shematic.
    ok
    here is the volkstrum + geb in proteus schematic and pcb, the part list, top (pdf), bot(pdf), included, can anyone to revise it is correct or not?, i replaced the kt8xx for the tip3x, and the kt315 for 2n2222 the pins are not the same, and i have a question... can i include a class a amplifier 10w in the tx coil to do more power more depth? and a mic booster in the rx? for 4ohm coil? anyone tried this? im crazy!
    ps. my english is weaker
    [edit]i forget to put the battery holes , you need to drill the holes for the battery [/edit]
  • kt315
  • and
    i confuse with the 4013 the pin 7 is ground according to proteus but in the pcb is in the negative voltage, what is the correct configuration? (im making the pcb with proteus )
  • mehdi
    I would be careful about what you substitute for the KT816 and KT817. Looks like the BD238 and BD237 have twice the current rating over what I used, so probably ok. KT315 - > 2n2222 is probably less critical.
    Hi Don
    Thank you for reply.
  • dfbowers
    Originally posted by mehdi View Post
    Hi silver
    i cannot get those transistor too but i get thistransistors that i thing those are ok but i am not sure yet;
    KT816 = BD238
    KT817 = BD237
    KT315 = 2N2222 ( BC146 is an old type and is extinct in my country)
    to dear Don
    wath is your opinion; we can use those transistors?
    mehdi
  • mehdi
    Originally posted by silver View Post
    Hi dfbowers
    yes i connot get the bc146 , 2n4920 , 2n4923.
    what transistors can be substituted for BC146 , 2N4923 , 2N4920?
    remission for my bad english
    Hi silver
    KT816 = BD238
    KT817 = BD237
    to dear Don
    mehdi
  • dfbowers
    Hi dfbowers
    I still cannot help you because I don't know where you live.
    Maybe do an internet search from the original components?
    http://matthieu.benoit.free.fr/cross/russian_equiv.htm
  • dfbowers
    Originally posted by and View Post
    btw i was made a list of materials, i hope not missing anything
    Nice!
    I'm not sure that my parts list was accurate or not. I might have ordered something for another project with the order.
  • silver
    Hi dfbowers
  • and
  • and
    HCF4520BEY
    for what is the HCF4520BEY "Counter Shift Registers Dual Bin Up Counter"? you order this in mouser but it doesn't appear in the schematic. o.o
