My Digital Pulse detector Delta Pulse 3
  • Malibu
  • Malibu
    Hi all,
    a month ago or so I received the kit, and I have some doubts.
    Can anyone help?
    1 - I think the R43 of 49 Ohms is missing.Yet must be of 49 Ohms? Tolerance??
    2 - Look at the R49 and R51. One is 5K6, but the other seems 4k7. Are be equal, 5K6?
    3 - R52, R53, R55. I can not put this resistance in vertical, the wire is short.? Can I solder a piece of wire? Or do I buy another?
    Thanks folks
  • jap
    Originally posted by pigeon View Post
    HI ALL
    can I replace with BU406D/BU426A/BU508A/BU807
    thank you
    Hi pigeon
    -U can not replace with [BU406D/BU426A/BU508A/BU807] its TR.
    -BT169D its SCR.
    ---For assist Download datasheet of BT169D & replace it In relation to the V,A,,With Note arrange of pin K,G,A
    best time
    j.
  • jap
    Hi Biogas
    -try with Coil-Calculator to test the table.
    http://www.geotech1.com/forums/showthread.php?17909-Coil-Calculator
    best time
    j.
  • Biogas
    Originally posted by jap View Post
    Hi Biogas
    -see!
    best time
    j.
    Hi Jap, hi All!
    I have got a table about a PI coil:
    Electronics project to make a metal detector based on the pulse induction principle. Use of a digital signal processor increases the detection quality.
    These coils is good for it or not?
    Ø 120 mm Round 36 Ø 0.40 mm / 0.14 mm2 405 µH 1.9 Ohm
    Ø 150 mm Round 31 Ø 0.40 mm / 0.14 mm2 394 µH 2.0 Ohm
    Ø 175 mm Round 28 Ø 0.40 mm / 0.14 mm2 387 µH 2.1 Ohm
    Ø 200 mm Round 26 Ø 0.40 mm / 0.14 mm2 406 µH 2.2 Ohm
    Ø 250 mm Round 22 Ø 0.40 mm / 0.14 mm2 380 µH 2.3 Ohm
    Ø 300 mm Round 20 Ø 0.50 mm / 0.20 mm2 390 µH 1.6 Ohm
    Ø 400 mm Round 17 Ø 0.50 mm / 0.20 mm2 396 µH 1.8 Ohm
    Ø 500 mm Round 15 Ø 0.50 mm / 0.20 mm2 400 µH 2.0 Ohm
    1.0 x 1.0 m Square 10 Ø 0.66 mm / 0.34 mm2 406 µH 2.0 Ohm
    1.4 x 1.4 m Square 8 Ø 0.66 mm / 0.34 mm2 387 µH 2.2 Ohm
    1.8 x 1.8 m Square 7 Ø 0.80 mm / 0.50 mm2 398 µH 1.7 Ohm
    They are corrects? In CAT5 wire whitch is the diameter of the Cu wire? 0,50mm?
    If they correct is, than correct your 0,4m coil plan? (3 turns CAT5, 3X8=24 turns, and here is don't 24turns, here is 17 turns)
    Thank you!
    Biogas
    Sorry, If I was don't unequivocal ...
  • pigeon
    hi all
    what is the equivalent of BT169D?
    thank you
    best time
    P.
    HI ALL
    thank you
  • pigeon
    hi all
    thank you
    best time
    P.
  • RS_Phil
    Thanks jap!!!
  • jap
    Originally posted by Saromines Ramiel View Post
    hello jap, Is there a full hex of delta pulse 3 available to download, or still a demo version?
    Hi Saromines Ramiel
    -still a demo version!!!!
    best time
    j.
  • liudengyuan
  • RS_Phil
  • jap
    Originally posted by Biogas View Post
    for Q8 z0103 MA, don't BT169D, and for Q3, Q4 B108 don't 2N7000! They are goods, or doesn't work it with?
    Hi Biogas
    -z0103 MA rong its a triac
    -B108 rong
    -BT169D
    -2N7000
    ---For assist Download for All datasheet of each
    best time
    j.
  • Biogas
    Hi All!
    I have got in store for Q8 z0103 MA, don't BT169D, and for Q3, Q4 B108 don't 2N7000! They are goods, or doesn't work it with?
    Thank you!
    Regards Biogas
  • volcano
    thank you Jap
    I will try
  • jap
    Originally posted by volcano View Post
    But it works very late and very short wave.
    I think that the problem is on the coil.
    thanks
    Hi volcano
    --good for success.
    --for the delay in the start-change vd12, C22,C24,C28.
    best time
    j.
