My Digital Pulse detector Delta Pulse 3
  • Originally posted by jap View Post
    Hi DianaBlu
    -May be the two LEDs connected wrong.
    best time
    j.
    The connections are OK, the anode is common, the cathodes goes to the 4094. When the leds should light? When something ferrous / non ferrous is detected?
    • Hi, how to increase the detection depth DP3 DP3 can you distinguish between types of metal, anyone answer me thank you
      • Originally posted by DianaBlu View Post
        goes to the 4094.
        Hi DianaBlu
        -its not 4094----->its 74 4094
        best time
        j.
        • Hello, everyone. Can anyone tell me of the DP3 PCB plate size
          • thank you nicolas for reply
            • help
              hi i now assembling one new pcb
              when i want to check circuit with guidance after assembly i can not see 17 volt in circuit with 7 poini.
              ( i cant not see 12 volt in 8pin tl062 and 16pin 4051 and ..... )
              plz help me to sole this problem .
              thanks
              • Originally posted by hadi-dindar View Post
                thanks
                Hi hadi-dindar
                -(Search in copper links there may be a break in the copper of pcb in the area) .
                -test if all the components and value in its place.
                -SeeClick image for larger version
Name:	part _power.jpg
                Full wishes for the success to complete
                best time
                j.
                • thanks
                  solved jap.
                  the irf9570 inside 7805 damaged . after change it the problem solved.
                  • hello,
                    i can't go on, can anybody say to me if 49ohm resistor exist?
                    i bought in a shop 49.9 ohm resistor, but not 49.
                    where can i buy it by internet?
                    i need R43
                    thanks.
                    • Originally posted by Malibu View Post
                      i need R43
                      thanks.
                      Hi Malibu
                      -U Can use R43= 49.9 ohm .
                      best time
                      j.
                      • Thank Jap.
                        Another question. See the foto.
Name:	la foto (4).jpg
                        Are the same resistance or are different. I know that they are 10k but are the same material? or are metal film and the others ceramic?
                        The question is, can i use any of this? Is the same.
                        Thank you.
                        • Hi Malibu
                          U Can use!=the same.
                          best time
                          j.
                          • Hi jap,
                            first thanks.
                            and another question,
                            i solder the holes like in the file "output job" ? the red lines?
                            is the good file?
                            Thank you, very much.
                              Hi jap,
                              first thanks.
                              is the good file?
                              Hi Malibu
                              -Yes,file "output job" are v.good,,,,,,,,read reply#356 .
                              best time
                              j.
                              • hi jap
                                hi jap and other best friends
                                i have one problem
                                when i install pic on pcb and want to turn on the detector my glcd can ton ably to show all thing .
                                please attention the this images
