My Digital Pulse detector Delta Pulse 3
  • mrmr16
    rais.mumbai , hex file is not free . you must buy it .
    go to http://www.teknolojiekibi.com/yeni site .
  • rais.mumbai
    dear pasha iwant delta 3 hex file please help me my email [email protected] please pasha bhai meri madad zaroor ki jiye i am new
  • mohandes
    hello hadi
    if i want make dps3 an you help me?
    are you ACQUIESCENT at this detector?about depth and ,...
    please tell me ok or no
    thanks
  • mohandes
    hi pasha
    ok
    i want to make dp3(that you send)
    we should just use coil 1m*1m???????????
  • Pasha
    Hi Friends,
    Delta Pulse 3 is a stabil detector as all delta pulse series and delta pulse copies. But, some peoples may be experiencing some problems about stablitiy due to automatic analog tune or faulty manufacturing or coil. For example some people using not rigid 1x1 meter coil and when coil yawns detector begins to signal. This is not detector or design fault. This is manufacturing fault. A lot of people are using tihs detector on the ground now without any problem. Sometimes some people send me some their delta pulse 3 detector that home made for repairment. And I saw a lot of problem on the boxing, or connecting or soldering or etc. on the detectors. So, I developed a new detector to solve stability problems and to simplify manufacturing. This detector has digital tune feature and very high stablity on the ground.
    About Delta Pulse 3S,
    This detector is entirely different detector. Only name is delta pulse 3. Circuit, softwere, working system all parameters is different and newly developed. Also, I am working on a PC software for DP3s for vizualization. You can examine from following link but you should become member to see photos and attachments.
    Regards.
  • mohandes
    Originally posted by hadi-dindar View Post
    hi mohandes . yes the stably problem solved in new version of dp3s. and new version is very stably .
    MOhanses i am from Iran , if you have problem about dp3 you can send me private massage .
    Hi hadi
    Nicolas says dp3 not good!!what is your idea?
  • hadi-dindar
  • hadi-dindar
    hi mr babak . you can buy pic via original hex program via karadag user in teknolojiekibi site . if you are in Iran , you must be pay 30$ in huseyin demirs paypal account and he send you a pic . if you are in Iran you can buy a original pic in iranian site.
  • babak-lashani
    hi my friend..i am new user in page...i need to dp3 hex file,,,,can you help me?
  • mohandes
    Originally posted by Nicolas View Post
    Hi friend Forget that
    The DP3 is a bad detector and not stable and have same problem for evryone not sicces for all
    The turk now work for a other DP3
    Look it
    http://www.teknolojiekibi.com/yeni/i...opic=3797.4320
    hi niolas
    is Dp3 solve this problem?
