My Digital Pulse detector Delta Pulse 3
  • eaglewings35
    Hey J., I took my DP3 to the shop and they said it was just some loose connections, nothing bad.
    Is there a process for changing out search coils?
    If I change to a dual coil, how do I make it see and recognize the coil?
    Kerry
  • jap
    Hi DianaBlu
    LF357=LF356.
    best time
    j.
  • DianaBlu
    A simple question: It seem almost complicated in my country to found a LF357. Everybody proposed me a LF356. I had a look to the datasheet, and seem that it works with lower voltages, with similar performance. Can I change them without loss in performance or
    without damage to the hardware?
  • jap
    Hi eaglewings35
    Yes, it's enough - Notable sheet is installed in Box by any way.
    -yes a process see link:http://www.youtube.com/watch?v=YXCt8QqHeFo
    best time
    j.
  • eaglewings35
    Also, Is there a process to change out search coils, to make the detector recognize
    it? How do you tune the DP3 to the coil?
    Thank you again,
    Kerry
  • eaglewings35
    Thanks Jap for the help.
    If I understand correctly, if I place a sheet of copper on the "Bottom" of the PCB and solder it to the
    negative battery, this will make it "Shielded"? Is this correct?
    Do I need to put copper paper any where else?
    Thanks again. Your help is much appreciated.
    Kerry
  • jap
    Hi eaglewings35
    You can work shielded(insulation) as you want by sheet paper of copper in the form of a paper cut dimensions same dimensions of pcb and put down at the base of the Box and be completely pcb above and welded wire and arrive to -E battery.
    best time
    j.Click image for larger version
  • eaglewings35
    I have not been able to get my detector to work, so I have taken it to an electronics shop
    and am having them check each part to make sure all are working. I understand that sometimes
    you get parts that are bad.
    But, I was informed that I should have the PCB in a shielded container to keep it from picking up
    outside signals. Does anyone have a thought on this? I was thinking that the coil needs to be shielded, not the box. Correct?!?!
    I have a plastic box with a snap lid that would make it waterproof.
    Thanks for all the input.
    Kerry
  • DianaBlu
    Hi all! I have big problems about the registration on the turkish forum. I don't receive the "activation link" email. I've already tried with 2 different nicks with 2 different email, no joy.
    Anyone else had this issue? Is a temporary thing or so? Any clue?
    Thank you guys...
  • jap
    Hi volcano
    -test & change Q3,4(READ DATASHEET OF U TYPE to now the pin GDS)(THE ERROR FROM Q4)
    - put type
    best time
    j.
  • danny475bek
    hi all
    thanks to those who are working on this nice project i know that there are some members who rely are working to full fill us with a new project
    ok i really wont to know which version of pcb board i have to print and which one is good and works well because i see a lot of versions maybe 3 or 4 versions and if any one in this forum can send me the hex file my e-mail is [email protected]
  • volcano
    Hi Jap
    I tried to adjust TR1 many times to do the calibration like this picture
    but the signal is always horizontal (sometimes is like a wide range which includes points) like this picture
    And I've been I doubt in the vicinity of 2n7000
    I have the following measurements
  • danny475bek
    hers my e-mail
    [email protected]
  • danny475bek
    hi all
    can any one please send me the real hex file not the demo one
    i will be very thankful to him
  • Nicolas
    Originally posted by jap View Post
    Hi Nicolas
    The real Hex hihihihi??? present at the owner-And possible requested from him.
    best time
    j.
    OK Jap thanks but just a joke
    I understand my colleague
