Hi volcano
see rar.
best time
j.
My Digital Pulse detector Delta Pulse 3
Hi Pasha!
I payed with PayPal on 10.12.2012. 41 Eur for Delta Pulse PIC, and PCB!
Please write me, this pack have you yet sending for me,or not??
Because I haven't got answer im PM from you, but I wrote to you 3-4 times already in this themen!
Thank you!
I'm waiting the answer and the Packet!
Biogas
Hi all, I have just some questions:
The P3 and P4 connectors are about "battery charger" and "backup battery", but how to connect them? I've seen a hires photo, and seem that P4 was jumpered pins 1-2, and P3 is not well visible.
"Charge1" led under the first 10000uF capacitor lights when...?
What's about the meaning of the two front panel leds?
Hi eaglewings35
because two coil must The match in the specifications ohm , uh.
-So you are using 2 coil do not match so it must control every time when you change the coil.
best time
j.
Hey J. I was just wondering if each time I changed the search coil (30 and 50) do I have to
change the settings?
Why cant I use the dual coil? (Whites TDI coil)?
Thanks Kerry
Hi hadi-dindar
How to make PCBs at home
in 1 hour & W I T H O U T special materials
---- http://www.riccibitti.com/pcb/pcb.htm
best time
j.
i cant print pcb on fiberglass fiber
i download original pcb from turkish site
but in this pcb the line are very Thick in Compact areas.
i need a original pcb with Narrow lines in Compact areas.
can you send me the original pcb with thin line in compacts space.
Hi hadi-dindar
None at now lay.out format of pcb of DP3.
--u can make it.
best time
j.
hi all friends and my best friend jap
i need the lyt format of pcb . i want to edit this pcb . i cant print this pcb on board . plz send me lyt format of dp3
Hi eaglewings35Originally posted by eaglewings35 View PostHey J., I took my DP3 to the shop and they said it was just some loose connections, nothing bad.
Is there a process for changing out search coils?
If I change to a dual coil, how do I make it see and recognize the coil?
Kerry
What is the problem ?- and your observations of the problem - put photo so that I can help.
-for dual coil no use.
best time
j.
