vandal pulse 1
  • #91
    Hello Bernte_one
    Ok, yes you are rigth i will first check for what you are pointing out.
    By the way, soldering a short wire btw the cristal case and one leg of capacitor close to the cristal will increase deep detection and also you get a stable signal.
    Finally what was your batteries long after they drain off?
    Nelson
    • #92
      And how much will cost this?
      • #93
        Hello my friend.
        About vandal1 wich is sasho design, have you got any others results to post?
        In my case, is working fine, but if you put 12 vlts to it it get unstable. Yes i know vandal1 must be supply with no more than 9 volts to work properly, but has i said before i just chequed sasho schematics with vandal circuit and bealive me , the circuit is the sama, components the same, tracks the same. So now i need to know if you have tested with more than 9 volts?
        Nelson
        • #94
          Do not try, very problematic scheme, second version is much better. regards
Name:	Vandal pulse 2.1.jpg
          • #95
            Problem is in to your empty head.
            • #96
              Hi sinko1
              Congratulation on your Vandal 2, but ....this is Schematic forum.
              Forum to share ideas in form of schematic.
              Where is schematic of your vandal 2 design? Nowhere!
              You only promote your product here with pure commercial intention.
              If you wish to promote your product only, then go to Buy-Sell-Trade forum.
              What of functionality has 3 controls on your picture of Vandal pulse 2?
              • #97
                New Sinko 1 schematic work perfect.Click image for larger version
                • #98
                  Hi sinko1
                  Ok, Im sorry. 3 are controls for sensitivity and treshhold and fine tuning. regards
                  • #99
                    Originally posted by scs View Post
                    New Sinko 1 schematic work perfect.[ATTACH]21572[/ATTACH]
                    Алкохола и висшето не прощават
                    • What do you mean not to try it?
                      I brougth you two units of these and now you said are very problematic scheme?
                      If this is rigth you are not to sirius about selling metal detectors kits, cause when i sell a metal detector i m resposible to sell a unit 100% working and if it has something wrong when it works i m responsible and i fix it, replace for a new unit or just give money back. So please don“t said is a problematic scheme, just be responsible for what you sell, cause my unit is working but with some problems about performance and stability
                      [ATTACH]21568[/ATTACH]
                      • Ha ha ha... The Balkans is that it ... do anything to surprise. It is also possible sale of the "cat in a poke"... Who can believe that he is the "Vandal pulse 2.1" is really good???
                        • Yes i think you are right, cause Sinko just send me a PM telling me he was just joking with another person.
                          Also what i did not like is that he made money with a detector that is not his design, cause is Sasho design (vandal1). I have chequed the two units i brough from him and both are the same circuit has Sasho schematics. Also he tried to confuse you just by errasing IC`S numbers, but for me it was easy to detect that is Sasho design. Now i had made just a small mood to this circuitts and are more stable than before.
                          Vandal 2 it seems the same circuits with some mods and has i said before i don“t care about selleing metal detectors that we found here, but changing names and saing that is your own design, thats not honest.
                          Nelson
                          • It says that sasho scheme design mean that it was his scheme? This is an old scheme stuart. Someone showed a video with a good working device from sasho?second version has nothing to do with this scheme. regards
                            • Hi Nelson.
                              If it's not a secret, how did you pay the two units (Vandal 1) + postage ?
                              • Originally posted by maikl View Post
                                Hi Nelson.
                                Hi mr.maikl notihng secret everyone can see it here http://www.geotech1.com/forums/showt...190#post159190
