SD2000
  • nejdet
    SD2000
    Finderskeepers, looks good device. After some time I can show you what I did .
  • javahitman
    Originally posted by Finderskeepers View Post
    To build 2 x double sided pcb's and fitted inside a Hammond alum. enclosure cost me approx. 470 US dollars. That includes pcb iron sheets, etching solution, solder and pcb cleaner.
    The final product looks good,
    Wonder if its possible to create a field test video and share it on YouTube
    Would be interesting to see the performance and how close it comes to the original
  • javahitman
    That total cost does include coil , battery ? Or just the components ?
    I want to try it too
  • detecto
    Is you'r SD2000 quiet like original?
    If you used BYV28-200V they have about 240-250pF of internal capacitance try to use MURS320 its have abouth 110pF internal capacitance
    GPX3500 use MURS320 as FRD.
    Cheers
    Detecto
  • Finderskeepers
  • javahitman
    Zed' schematic is correct as i have got my clone working. Do not use other schematics as they are incorrect. Hole thru parts can be used apart from a few parts that are only smd. Download all data sheets for all parts and study them. This is a difficult, fustrating, costly & time consuming project, but rewarding when completed. I highly recommend that you use a minelab monocoil.
    how was the approximate total cost for this project ?
  • Finderskeepers
    You can do it!
  • porkluvr
    Originally posted by nejdet View Post
    I understand your doubts Porkluvr I think so, but I will try
    Well, I wish you success. Maybe YOU will be somebody who can post a correlated PCB / schematic combination, with a "thumbs up".
    I just don't believe what I've seen so far, it's been too fragmented.
  • nejdet
    SD2000
  • porkluvr
    Originally posted by detecto View Post
    Hi you could not imagine how difficult is to draw good PCB for SD2000,
    Building SD2000 is more then worth you will see .
    Detecto
    Your statement seems to predicate that their is an accurate schematic/PCB pair available.
    If so, could you or somebody please post a link to said schematic/PCB pair?
    With due respect to those who seem to have had some measure of success with cloning the SD2000, there is not a lot of super reliable data (especially considering the complexity of the project. Maybe I've missed something.
    Forgive me, but I have my doubts.
  • nejdet
    Thanks, Still Picture these have them. We see our baby and I can not write anymore ...
  • detecto
    Hope i unerstand you
    You can't use DIP packages for SD2000....
    this picture will help you....
    Detecto
  • nejdet
    SD2000
    I made boards DIP elements but I'm not sure it will work. Bothers me that the scheme has some inaccuracies. I think it gradually revived and began the first of the power module and sound-they are on a board. The second is the generator of the transmitter. The third PCB is the receiver, demodulator and filters. Google translator is ......
  • detecto
    Obviously the topic is difficult . I have attempted to create PCB of this device. It was a pretty well-at least I think so. But I can not implement them due to lack of time. Rose 3 PCB with dimensions 100 mm X 140 mm. There are some errors but time will tell. Can anyone say whether it is worthwhile to copy this unit. Thank you . Sorry for bad English but translated by google translator
    Detecto
  • nejdet
    SD2000
