Range and frequency.
  • Range and frequency.
    Bob
    I have tested different frequencys from 40KHz
    to 620KHz and I belive the best all-around
    frequency is 200-250 KHz.
    40K. I did get a range of 2500 meters but
    no resolution at all. However I could penetrate
    20 meters of the seafloor mud.
    100K, range of 400 meters but wooden
    wreck is hard to see.
    200K I got a range of 200 meters, good signal
    level and ok resolution.
    500K good resolution and 100 m range.
    620K 80m range with a transducer only 100mm long.
    Design example for 250K:
    Aperture of 400x6mm.
    The wawelenght will be 6 mm.
    Horisontal beamwidh 6/400 radians = 0.9 degrees.
    Vertical beamwidh 6/6 radians = 60 degrees.
    It is difficult to do exact calculations since the
    exact frequency is unknown until the transducer is ready.
    It seems that the free crystals behave slight
    different to the one put into the transducer.
    I let it be what it will be and tune the electronics
    to fit the transducer.
    As example my 200K crystals become 220K when the
    transducer was tested.
    Sture
    Re: Range and frequency.
    Sture,
    This information is really great! Thanks!
    When you have a beamwidth of 60 degrees, how do you determine the angle of the transducer on the fish? Do you just mount it horizontally, or angle it down somewhat?
    Also, with regards to the steel beam you mentioned earlier, what would the width of the beam be? should it be the same as the transducer width, or if it doesn't matter, can it be wider to provide more structural stability??
    Finally, I was wondering about obtaining crystals to test with. Do you know of a supplier that is resonably priced? Also, have you used different materials? Is there one material that is clearly best for this application, or are there trade offs between materials?
    -Bob
      Bob,
      I got a quote for piezo ceramic plates 1.4" x .35" x .13" thick. 25 minimun for $4.06 each. 2 week lead time. I plan to mount 12 end to end to give me a .4 deg horizontal and maybe 50 deg vertical @500 frequency.
      Tod
        Tod,
        When you order these, can you supply the list with part number, contact info, etc.?
        Thanks,
        Patrick
          Piezo Kinetics Inc.
          P.O. Box 756
          Mill Rd.
          Bellefonte Pa.16823
          Harry Shirey, Sales manager
          814-355-1593 x204
          P.N. SP1.4-0.130-0.325-402
          Let me know if any one els wants to order so we can put the order in at the same time. That might help Harry.
          Tod
            Tod,
            When do you plan on ordering them?
            Patrick
              The downtilting angle of a sidescan transducer
              is normally 20 degrees but it is not critical.
              "Steel beam" ? I not sure about the question.
              I guess it is about the steel backing on the backside
              of the crystals and this have nothing to do with
              any angle.
              Price for crystals is little tricky since I found
              it complicated to buy small amount of crystals.
              Price in larger batches is however less than
              10 USD /pcs.
              Sture
                Maybe Friday. I'm going to get 25 for my self,that takes care of the min. how many do you want and does any one else want some?
                Tod
                  I would be interested.
                  Do they come in different thicknesses? That is one issue that I am still unclear about.
                  Perhaps Sture can help with this!! He sent me a n email at one point, saying that his elements were 3x4x50mm. He has explained how the length and width affects things, but I am not sure about depth..
                  I am going to make a separate post about materials. Perhaps we can share ideas on other things as well.
                  -Bob
                    Tod,
                    I am interested. However, I might suggest that you wait a few days until everyone is in agreement that they are the best choice.
                    Could you hold off until next week on the order?
                    Patrick
                      No problem, I'll wait.
