I was initially interested in using a steel bar to align the transducer elements, but then Sture explained that they detached in the transducer he examined.
I guess the reason I didn't want to use a cork backing was the need to keep the elements aligned to .1mm might be hard with a soft material like cork.
Sture said that he was able to get good attachment to a steel bar using a different glue. Perhaps there are newer adhesives out there that will hold up well.
Another idea might be to put a bar in front of the crystals, that could help match the acoustic impedance. If it were an insulator, 2 leads would still need to be soldered on, but if it were a fairly stiff material, we would still get the alignment benefit.
Finally, if we did use a steel bar, a redundant lead could still be connected to the element, so it would still be connected electrically, even if the glue failed.
Just some thoughts.. perhaps others have some ideas..
-Bob
-Bob
I have done a
