As you can see, I hacked a fish together in about 2 hours in my basement (not my shop). It took many hours to tune the fishfinder to my ducer. I used a 55 gallon drum filled with water in my basement so I could hook up my old Textronixs Type RM35A oscilloscope. I first got readings from a fish ducer I new worked well and than hooked up mine and stared to turn pots until it looked the same. Not easy with no instructions but I did have a schematic. I brought lead and duct tape with me out on the boat for finial balancing. A real class act. The fish performed extremely well, steady as a rock.
Field-test
Field-test
As you can see, I hacked a fish together in about 2 hours in my basement (not my shop). It took many hours to tune the fishfinder to my ducer. I used a 55 gallon drum filled with water in my basement so I could hook up my old Textronixs Type RM35A oscilloscope. I first got readings from a fish ducer I new worked well and than hooked up mine and stared to turn pots until it looked the same. Not easy with no instructions but I did have a schematic. I brought lead and duct tape with me out on the boat for finial balancing. A real class act. The fish performed extremely well, steady as a rock.Tags: None
Field-test
This is a steam schooner in 50 feet of water and a relief of 5 feet. The ducer was at 45 degrees. I can see how important TGC (time gain control) is. If not enough gain you would not see the wreck (would be white), too much gain and all you see is black. I see how Sture did it, does any one else have a way I could do this in line with the gain control knob (it’s a 5K pot). I’m not good at designing circuits but with the right idea and components I can hack my way through the rest by t+e (trial and error).
Tod
Re: TGA's
>I can see how important TGC (time gain control) is. ...does any one else have a way I could do this in line with the gain control knob (it’s a 5K pot).
How are you doing the time gain control now? We (Analog Devices) have TGAs (time-gain amps) that are used in the medical ultrasound market that might work well for sonar. I believe that one is the AD600 - I will see what else we have.
- Carl
