Hi everyone !
I've just started my project building a SSS.
First plan is to make a Dan Fountain "copy" to learn and make tests. I'm using a Fuso 108D writing echosounder. It's operating on 200 kHz and has a range of 150 m. Do not know the output power yet but I will measure it soon.
As a start I will use 5 cheap Thru-Hull transducers from Airmar. My plan is later on to design and construct my own transducer.
Has anyone tried to make a transducer from Piezo Film?
I have been studying the material from Measurement Specialties Inc (www.msiusa.com).
They are selling the film in "raw" sheets as well as tiles (film laminated with aluminium) 1" x 1". The tiles are made to fit sonar designs and comes out in only $25USD.
My plan was to buy a sheet (8" X 11") and cut into a suitable size to get desired beam angle.
Then laminating it onto some material to get desired resonance frequency.
I know Piezo Film has some disadvantages but also some very great advantages as very high sesibility.
Anyone tried to use Piezo Film transducers?
Also have some ideas about materials to use as acoustic window and absorber. What about using stearine as window? Of coarse it's sensitive to mechanical damage but it got a suitable speed of sound (1380 m/s) and is easy to apply (without bubbles) and to remove if wanted. I also belive its very good to keep water out of transducer. As absorber I was thinking of some kind of rubber (40-149 m/s).
Anyone has any suggestions or ideas about this?
Another plan is to digitize the signals from the transducer utilizing the sound card (line input) on my PC. It is fairly easy to write a software in VB for this. I will make some experiments this summer with a PC oscilloscope software called OSCI which uses the soundcard as input device.
Keep up the good work,
Best regrds,
Per
Best regrds,
Per
