Side Scan Sonar Edge Tech EG&G 272T / wreck hunting
On ebay:
SONAR A BALAYAGE LATERAL
Side Scan SONAR Edge Tech EG&G 272T towfish, 100 Khz Perfect state.
The best sonar for wreck and shipwreck research & recovery, treasure hunting, wreck hunting.
This Side Scan Sonar been used for a long time but completely refited and repainted with EG&G logos.
Tested recently in shallow water, working well.
Two pairs of wings, nice wooden white box, 55kg .
More informations, sonar imageries, shipwrecks and mosaiks on www.ceresm.com
Feel free to contact directly www.ceresm.com for further informations
272-T Tow Fish
Frequency 100 kHz - 105 ± 10 kHz
Horizontal Beam Width 100 kHz – 1.2° (3 dB points)
Operating Range (maximum) 100 kHz – 500 meter swath
Optimum Operating Depth 1000 meters
Tow Cable Type 7 conductor
Tow Fish Diameter 11.4 cm (4.5”)
Tow Fish Length 140 cm (55”)
Towing Speed (operational) 3 – 5 knots
Weight (in air) 25 kg (55 lbs)
Weight (in saltwater) 12 kg (26 lbs)
Provide High Resolution Seafloor Images
The Model 272 towfish is a hydro dynamically stable, towed body that contains the electronics and transducers necessary to generate and receive side scan sonar signals. It is designed for use at depths up to 1000 meters. Various tow cable systems provide the mechanical means for towing the fish near the seafloor and the electrical means for powering the fish, triggering the transmitters, and sending the return signal to the topside for processing and display.
The Model 272-T towfish incorporates circuits for transmitting and receiving the 100 kHz side scan sonar frequency.
The Model 272-T towfish feature the patented Saf-T-Link® shear pin feature. When cable tension on the towfish exceeds 180 Kg (400 lbs.) due to snagging on the seafloor or mooring lines, the nylon pin shears and the electrical connector between the cable and tow fish separates. The towfish then "flips" 360 degrees, transferring the tow point to the nose of the towfish and allowing it to be pulled clear of the obstruction. Normal operation is easily restored by remounting the towing arm with a new shear pin and refastening the connector. If only the tail fins snag, they will fall away and be loosely held by a nylon cord. The cord is designed to break if the snag persists to avoid loss of the towfish.
272-T features a patented Time Varied Gain (TVG) circuit that compensates for the known signal losses versus range. This not only facilitates processing, but also reduces the dynamic range requirements of the tow cable, thus reducing the susceptibility to electrical nose pickup.
272-T can be towed with lightweight Kevlar tow cable or, for deeper waters, by double armored steel-cables.
FEATURES
operates at 100 kHz, Time varied Gain, Saf-T-Link towing arm, Breakaway tail fins, Lightweight for one-person deployment/recovery, Corrosion resistant
Rugged, modular construction for ease of maintenance
APPLICATIONS
Shipwrecks research & recovery / Hydrographic surveys / Channel conditioning and clearance surveys / Geological surveys / Cable and pipeline surveys / Search and Recovery / Site selection surveys / pre/post dredging surveys / Mine countermeasures / Treasure hunting
I. SEAFLOOR SEARCH
This is the process of detecting and recognizing a seabed anomaly using sonar for the purpose of identification, disposal, or retrieval. Detection is a function of sonar design and acoustical physics while recognition is highly dependent upon the eye-brain interface and operator experience. Typically, small objects on the bottom can be partially or completely buried, or, in shallow or deep moored configurations. Small objects are detected by the size and shape of the acoustic shadow, which is a derivation of the acoustic reflection, fish altitude, and grazing angle at which the sound waves strike the object.
Applications for marine search include: Explosive Ordnance Disposal, Q-Route Survey, Site Clearance, Search and Recovery of Downed Aircraft and Sunken
Shipwrecks.
Mine Countermeasures
The search and disposal of underwater mines requires constant effort on the part of militaries worldwide. Shipping channels must be kept open and free from mines.
Over the past decade, Sonar data acquisition and image processing system has played a critical role in the identification of underwater mines worldwide. 272T have been used internationally.
Aircraft Search and Recovery
Edgetech products have aided in the search and recovery of downed commercial and military aircraft worldwide.
Search and Recovery of Shipwrecks
Some of the world's most highly publicized shipwrecks have been found with 272T
Small object Search and Mining
II. HYDROGRAPHIC SURVEY
This is the mapping of the seafloor topography utilizing various sensors, including single and multibeam sonars. Surveys are conducted to produce nautical charts for safe navigation or to provide the detailed mapping of pipeline and underwater cable routes.
Pier and Harbor Survey
The Sonar data acquistition and image processing system provides detailed information on survey depths of harbors by providing real-time graphical displays of data. This information allows for safe navigation of marine traffic. Isis also offers details of the underwater condition of harbor walls to help identify weaknesses and hazards.
Breakwater Survey Breakwaters are built to protect harbors from damaging storms. The harsh marine environment often degrades the breakwaters leading to unsafe navigation around the area. Locating damaged areas of the breakwater before a failure is critical. This can be accomplished with 272T Sonar .
Dam/Reservoir Survey
The Sonar in conjunction with multibeam systems make it possible to map intricate stilling basins associated with dams and reservoirs. Surveys are conducted to detect hazards caused by erosion, or to provide valuable, up-to-date information for the accurate computation of water storage volumes.
III. DREDGE WORK
Pre/Post Dredge Survey
Two surveys are usually conducted to support dredging operations; Preliminary and Post survey operations. This information allows the dredge to determine how much area is required to be removed and to then produce a final survey to verify that the depth meets all navigation requirements. High accurate survey data is required. The 272T sonar has gained international acceptance as one of the most efficient and accurate data acquisition and processing system.
Dredge Support
During dredging operations, survey support in the work area allows the operator to determine if the correct depth has been achieved. An isolated pile or missed area can result in higher costs if the dredge must return to the area. The sonar can provides real-time coverage of the area, providing very accurate depth measurements for the operator.
IV. SAFETY AND INSPECTION WORK
Bridge abutment Inspection
Every railroad, roadway or bridge over a river is suspect to the potential underwater erosion of its supporting piers. (A high current area can quickly lead to erosion and possible failure of the structure.) Rivers can quickly erode the sediment beneath the support, weakening bridge supports and potentially lead to structure failure.
River Flooding Support
Several countries have experienced severe flooding to low lying areas because of unusual changes in World climatic conditions. Water levels of major rivers have risen and broken their banks.
Rock Dumping
Rock dumping is the accurate placement of rocks onto the seafloor to achieve a specific objective. Typically rocks are placed over an exposed pipeline laying on the seafloor. Time and materials are saved if the placement is exact.
Pipeline Inspection
Underwater pipelines require periodic inspections and maintenance to reduce risk. The inspections determine if they have become exposed, or if any erosion beneath the pipeline may have created excessively long spans, making it vulnerable to rupturing. The Sonar Pipeline Inspection System tracks up to four pipelines simultaneously, generates on-screen tags, reports in real-time and automatically detects free spans, scour, burial and other anomalies.
On ebay:
272-T Tow Fish
FEATURES
APPLICATIONS
I. SEAFLOOR SEARCH
Shipwrecks.
III. DREDGE WORK
Dredge Support
Rock Dumping
Pipeline Inspection
