I've finally gotten around to starting my hobby metal detector design. I'm really more interested in the design and construction aspects than the actual outdoor all day in the summer digging into dry dirt aspect. I'm trying to get some idea on the scale of some things, as well as why some of my ideas will either work, not work, or etc...
I've been debating between PI/VLF mainly, but I do wonder if there isn't a way to modernize the BFO concept.
For the VLF front, I understand that the idea is to transmit a waveform that has generally lower frequency content in the 10-50khz range. A second coil is placed in what is nominally a dead zone for the tx coil. It only receives a signal when this balance is disrupted. My main questions are:
1.) for a reasonable tx coil, such as a 20 cm diameter, what is a good range for the number of turns and for the approximate load impedance when driven? I know it would depend on other factors, but what would some low/high examples?
2.) What would a reasonable drive level be for the coil if the goal was 30cm? (or maybe 20 cm, in the area where this will actually be used the amount of digging that can be done unassisted is fairly small). The location would be in the Arizona desert, USA. I'm not sure on the mineralization of the soil.
3.) What is a reasonable rx coil and rx signal strength?
4.) What about bandwidth? can the same rx/tx pair work equally well at 10khz and 40khz? or would it be expected to work well only at one or the other with near zero output away from resonance?
5.) Finally, what is the preferred driver? Something like an H-Bridge where the coil is switched between 2 (or 3) discrete levels, or something like a linear amplifier, where the output is much more linear?
For BFO-inspired ideas, I understand that BFO works by using an oscillator that is pulled when the inductance/resistance/capacitance of the coil changes due to the presence of various metals.
6.) Would this idea also work with a single tx/rx coil where a voltage is driven onto the coil and a current is measured?
My thought there is that it might be possible to make a wideband detector by measuring the coil impedance over a wide bandwidth, and extracting some of the parameters. This would probably linear amplifiers for the driver and current amplifier.
