What is best detector / Which circuit you made was better ?
  • What is best detector / Which circuit you made was better ?
    Hi Guys,
    What is best detector for detecting iron ball in more than 1meter deep
    i saw many post in forum finally i didn't understood what is best really
    what about Miner 4 anybody built it, any result ?
    i made HH1 but i need more powerful device
    Any circuit ?
    - Sam
    What is diameter of your iron ball?
      I think Mikebg would be the right person to address this question. He is mostly into finding meteorites i.e. small iron. Whatever works for him must be good.
        Best result on iron targets, i achieved so far, was not with detector but with magnetometer.
        Rusty iron piece 12cm x 5cm i discovered at 60cm depth, with very strong signal.
        Considering target size, i am sure it is the very best result for me so far.
        If you want just to search for irons; than there is nothing better than magnetometer for such task.
          Agree, what is his detecting shape (circle) at 1m of depth? Strong pinpoint or detecting circle of say about 25cm?
            15cm / 6inch Iron Diameter and if important the area fills by water.
            - Regards
              tnx for answer "ivconic" which one of this circuit you built ?
              - Sam
                - Regards
                I guess HH1 with proper coil (of about 70-80cm) can manage 15cm iron ball at 1m depth and more, even in water area.
                  John Becker's
                    Hi Sigman
                    DELTA PULSE 2 can detect iron ball(d=15cm ) in more than 1meter deep.
                    best time
                    j.
                      Thanks WM6 I'll go to make it, how many turns and which AWG ?
                      - Regards
                        - Regards
                        For coil diameter of about 75cm you need of about 15 turns >AWG#22. It is not so critical, you can experiment with a couple more turns and AWG to #18 (speaker cable can do well). You need to tune your new coil to detector with damping resistor for better results (despite ferro targets are not so conclusive regarding this).
                          Originally posted by jap View Post
                          Hi Sigman
                          best time
                          j.
                          Hi Jap
                          Delta Pulse is good detector i interest to make it but there is a lot of post about it and i donno what of them are good for me, do you know any link(s) or documents (such as PCB, Components, Coil, Troubleshot, ect.) ?
                          - Regards
                            http://compass-metal-detector-forum....4/DSC07068.jpg
                            Tnx for photo
                              Hi Sigman
                              Tech Forum -->Delta Pulse,,There is an explanation for everything for DP,COI.
                              DELTA PULSE 1 REPLY#852 link http://www.geotech1.com/forums/showthread.php?8003-Delta-Pulse/page35
                              AND SO ON.
                              best time
                              j.
