SD2200D with 3 ohm coil
  • SD2200D with 3 ohm coil
    Hi
    Has any one used a 3 ohm 18 inch coil on an un modified standard Minelab sd2200d?
    The normal coil seems to have an 18 ohm resistance.
    Will the coil cause damage to the detector because the 3 ohm coil is drawing too much current?
    Any one have the schematic of the output or driver stage of this detector?
    The normal Mono coil for Minelab PI is .4 ohms and inductance of 300uh if you are reading 18 ohm it sounds like you are reading the RX coil on a DD if not you have a problem with your coil.
    Regards, Ian.
      Hi Ian,
      do you know data for SD series DD coil?
