hi all , i have been using my xlt spectrum machine , suddenly when it switched it off then turned it on ,it can ground/air balance, i thought it may be coil problem , i tried to change it , but the same problem , also i tried to reset it many times the same problem , any one can help me to know where is the problem , i have good knowledge in electronics does any one know , which parts are responsible for auto ground/air balance , thanks in advance
porblem with my xlt spectrum
To me the same thing happened with my XLT. The solution is easy. I removed the microprocessor carefully, I cleaned the socket and the pins of the microprocessor with industrial alcohol and ready. Sometimes the pins are oxidized. Greetings.Originally posted by ahmadjordan View Posthi all , i have been using my xlt spectrum machine , suddenly when it switched it off then turned it on ,it can ground/air balance, i thought it may be coil problem , i tried to change it , but the same problem , also i tried to reset it many times the same problem , any one can help me to know where is the problem , i have good knowledge in electronics does any one know , which parts are responsible for auto ground/air balance , thanks in advance
