Nice design !
You can probably omit D2/D3 clipping diodes as they are already inside the PIC ?
I also have had problems in the past using the MCLR pin 4 as a pushbutton input. The controller would sometimes reset when holding the search coil near a damp grass surface. The solution is to add a 100nF to ground (in parallel with the pushbutton).
Best regards,
- Bernard
My Pulse Oscillation detector project.
What I mean is the following:
Sampled Coil "bits": 000111100011100011110000111000.....
Reference "bits": 011100001111100001110000...
XOR: 011011101100000010000000...
Low-pass: 111111111100000000000000.. -> output (down mixed and filtered output beat frequency)
Very simple to implement and very effective. Can be implemented in an endless loop.
I'm not familiar with the PIC pins.Originally posted by Qiaozhi View PostNote that Teemo has labelled pin 3 of the PIC as "RA4/C1IN1", which probably tells us that he's using the built-in comparator.
But I personally wouldn't use the comparator (IRQ).
The continious down mixing is simpler and faster.
Note that Teemo has labelled pin 3 of the PIC as "RA4/C1IN1", which probably tells us that he's using the built-in comparator.Originally posted by Aziz View PostNo, the ADC would be too slow. For the most of the time, the coil voltage would be at high levels and clipped therefore.
There is a 1 bit ADC implemented: lo/hi input line detection.
You can sample the bit very fast (just read the input line). Mix it with a reference nearby the resonance frequency. (The easiest and fastest mixer would be an exor operator).
No, the ADC would be too slow. For the most of the time, the coil voltage would be at high levels and clipped therefore.Originally posted by joop View Postah, the clipping diodes, of course... But amplitude could still be measured after a time delay when amplitude is below the clipping voltage...
No, you can't measure the amplitude as it will be clipped by the diodes. The coil induces a high voltage. It is typically driven at approx. resonance frequency of 77 kHz. The only way is to detect the frequency and mix it down by an internally reference (a simple xor) and put the mixed output to the piezo element.Originally posted by joop View PostSo the search coil together with the 47nF capacitor form a resonant circuit which is excited by the FET. A change in amplitude is measured at the PIC input. A resonant PI?
I like it's simplicity.
Good work.
Hi all,
according to the schematics and the processed information (debugging the hex code isn't necessary):
It is a BFO. (Or some kind of frequency shift detector.)
Hi
So here I try to post schematic, hex file and the new thing --partslist.Attached Files
