Pulse Induction History and Theory
  • Baterista
    This is the only one in the world. It was originally built for a specific purpose - to find silver bars from the Atocha. It has been used for other searches since that time, but I do not have any details.
    Eric.
    Thanks Eric, for the pics and information. I think this machine is playing the role of treasure.
  • Ferric Toes
    Originally posted by Baterista View Post
    Very powerful, this is a prototype?, or other were produced.
    Eric.
  • Baterista
  • sinclairuser
    Nice pics, a true work of art (real electronic art!).
    Obviously built to last!.
  • Ferric Toes
    Well it arrived back today after 32 years away. Looks like it will need some TLC but I gather it still works and inside looks good. Here are some pictures taken at the time in my Irish factory where it was made. I think I need an overhall too. Was my hair really that colour?
    Eric.
    Not too bad inside. The 22,000uF TX reservoir cap dominates the scene, with big heatsink for 2N5883 driver and PT7505 80A power transistor behind (no mosfet power then). Heat extraction fan at right end of HS. Relay is to charge capacitor up slowly in standby position on front panel switch (avoids melt down of switch with 50V supply). Pulse generator and sample generator board to the right, and RX to the left.
    Eric.
ID:	336072Click image for larger version
  • Altra
    These photos are great. A pioneer in pulse induction and electronic shipwreck recovery.
    You probably had your hands in this also
  • Ferric Toes
    Thank Eric
    This is so interesting right up my street, shall print all these off and keep them forever.
    Many many thanks
    Eric.
  • satdaveuk
    Thank Eric
    Many many thanks
  • Ferric Toes
    High Power PI still in use after 32 years
    Not quite so ancient, but a pure PI built in 1981 for Mel Fisher in his search for the "big pile" of silver bars on the 1622 Atocha wrecksite off the coast of Florida. This detector can pulse 50A through a large coil towed on a sled along the sea bed. The detector electronics was housed on a survey boat along with its associated chart recorder. Power was 48V from marine lead acid batteries. Short delays were not necessary as the TC of a single bar was several milliseconds, and there was plenty of signal at the 250uS minimum delay on the switch. Sea water response was also minimised by this.
    This unit is still being used by the present owner, who was also involved in the Atocha search, and I will be furnishing him with some coil details.
    Many thanks to Mikebg for helping to re-establish this contact between the owner and myself.
    Eric.
  • mikebg
    UXO detector Gutton 1915
    Below is attached the first official description of UXO detector GUTTON 1915 which circuit diagram is given above:
    The attached file was made by OCR from a publication of the French Academy of Sciences
    The text is divided in paragraphs to edit the machine translation, but the results of machine translation from French to English is bad. Let somebody, who knows better than me both languages, make the translation. Here is the OCR generated file:
  • mikebg
    PUBLICATION IN NEW ZEALAND
    Publication in New Zealand
    Ashburton Guardian, Volume XXXV, Issue 8353, 21 January 1916, Page 8
    Attaced is an OCR generated file.
  • mikebg
    OTHER ANCIENT METAL DETECTOR
    Académie des sciences (France)
    CHIRURGIE. Sur l'emploi de la balance d'induction de Hughes pour la
    recherche des projectiles dans le corps des blessés. Note (1) de M. A. de la
    Baume Pluvinel, présentée par M. G. Lippmann.
    _____________________________
    (1) Séance du 20 septembre 1915.
    Academy of Sciences (France)
    SURGERY. On the use of the induction balance of Hughes to
    search projectiles in the body injured. Note (1) Mr. A. de la
    Baume Pluvinel, presented by Mr. G. Lippmann.
    (1) Meeting of 20 September 1915.
    Here is the OCR generated txt file for machine translation:
  • mikebg
    I made with OCR a txt file for machine translation of the article mentioned in post #69
    The results of machine translation from French to English is bad.
  • mikebg
    I'll have to decline for now, the unit is in storage and I don't have time to pull it out & mess with it.
    This was joke, but serious, you can buy a PDF file for $ 1.95
  • Carl-NC
    Carl, I do not want to waste your time, but I'm very interested in the circuit diagram of this machine because it looks like it is a step backwards compared to the machine builded in 1915. Here is attached that circuit diagram (in my opinion). I need a more detailed picture of your machine to see how is adjusted the angle between the poles depending on the operator's height . I'm interested in the design of vibrating interrupter and how seems the capacitor with large capacitance.
    In general, to satisfy my desires, you should appoint a curator of your future museum. He will take pictures, draw circuit diagrams and prepare postings for the forum.
    Thanks in advance!
