modify power supply of Buccaneer of Andy Flind
  • modify power supply of Buccaneer of Andy Flind
    Would someone know how to tell me that change needs to do to the circuit of Power supply of the buccaneer of Andy Flind if to the place of D4 I put a diode zener from 2 Volt?
    the D4 I don't succeed in finding him in commerce.
    Thanks.
    Re: modify power supply of Buccaneer of Andy Flind
    Hi Marcello,
    If you are using a 2 Volt zener instead of the 1.2V reference then you will have to change R33 from a 12K to a 24K. That should work.
    Reg
      Hi Again,
      If you want to use a different zener, lets say a 3V, then you would have to select R33 to have a voltage drop across it to be 3V. In other words for a 3V zener then, 3V=6v(R33)/(R33+R32).
      Reg
        Thanks, everything has worked.
