revolution?
    INPHAN coil configuration
    Aziz,
    What is your opinion on INPHAN (inductive Phase Analysis) coil configuration
    "INPHAN-Spulenkonfiguration"
    "E-Faktor Vermessung MTC Sonde"
    Note that the relative rotation of the two layers is not shown in Fig. 3 of the patent.
      Patent attorneys will tell you there is
        Aziz,
        Hi mikebg,
        I haven't looked at it deeply. I have absolutely no idea at the moment.
        But interesting and novel concept.
          have tested the pre sell version last weekend
          unit has problems with my wet loam / clay ground in the garden
          think it is e result of uneeficient shield grid (etched pcb shield)
          indoor in air it works good but on heavy wet ground ?
          is anyone interesed that i make a special test / testobjects
          distance test in air etc?
            is anyone interesed ....regards
            Do you have an operating manual?
              More probable cause is inadequate GEB. Wet clay surely has GEB somewhat skewed against the ferrites.
                It has a self calibrating mode, and a indicator for mineralized soil.
                But in the manual ist written that you can continue when mineral ground is detected it is no problem.
                Yes i have the manual here.
                In air i got good result for such a small coil, must see maybe i do something wrong while calibrating outdoor.
                IT works also like a cable finder (maybe pinpointer) if you hold button 2 the performance is decreased 30times.
