Hi all,
Just soldered up my surf pi kit, plugged in the batteries and it worked first time. Havent touched the pots or anything so still need to learn how to tune it. But i get 12cm on a small coin and 30cm on an aliminium can using a 10cm test coil. That is around 3 times better than the Russian Pirate
Quick thanks to the people who made the surf pi possible. Very professional kit, simple and easy and works first time.
I didnt clean the board or tune it so results may improve.
Poor video quality from my mobile phone :P Turn your volume down, this thing is 29 times louder than the russian pirate :P
). The noise is rather random, unstable and at low frequencies. The amplitude is of a spike nature (short durations). I'm more curious than troubled by it. Don't plan to search for treasure in my basement however
. One way to possibly limit the noise - if its not a layout issue - would be to filter the audio and convert to a DC level. Then use a VCO to control the audio like a 555 I have seen in some MDs. Kind of a limiter using longer time constants. May or may not work.
