Hello,
My 4.5 years old (SMT) White's TDI won't start when the outside temperature is below 10deg Celsius. The battery status leds light up, but there is no sound from the speaker. After several tries to turn it on, eventually it would sometimes turn on and then work just fine. This only happens in winter. No problems whatsoever in the summer.
Could it be the crystal that causes the problem?
The micro will be the square part with lots of legs! If your still unsure, post a photo. Also try heating up the micro a bit with a small hot air gun just to confirm that this method will work.....
The micro is the one next to the 6 pin header, the so14 device.
