Originally posted by KahlesMilcon
Eric.
Do some detectors with the frontend, or all electronics, closer to the search head (Ebinger?) route the actual coil wires without joints into the detector electronics, as twisted pair? The shield, if necessary, would be another factor. All coax cables I know of have a woven and/or foil outer conductor, which makes for eddy currents. A section of coax is not as bad as a piece of copper tube in tests but still noticeable compared to the center conductor alone (which would be easy to fix). Litz techniques for coax cables, or just twisted pairs and high CM rejection?
