TOMB RAIDER
    My assessment is that the Tomb Raider really nicely packaged Delta Pulse...
      very bad judgment !Delta never worked I totally atypical !
        and this is the same question and assessment was deep hunter because the delta is constantly returns for forums ! has nothing in common with by any detector from any forum !
Name:	tomb raider - duplo polje s.jpg
ID:	338431 Click image for larger version
ID:	338431Click image for larger version
Name:	d polje tobm raider.jpg
          depth 180cm
          underground 3 kilos of coins !
            double field 50 cm coil !
                Hi Orbit
                do you own that 50cm coil ?
                have you done any tests as to what are the smallest metal objects it will detect, coins for example.
                  [ATTACH]27521Click image for larger version
ID:	338646[/ATTACH]Click image for larger version
ID:	338642Click image for larger version
ID:	338643Click image for larger version
ID:	338644Click image for larger version
                  that to detect coins ,example, a gold ring 3g detected at 60cm .
                    There are two versions one with a magnetometer ,and the other without a magnetometer with LCD display !
ID:	338647Click image for larger version
                        Thanks Orbit
ID:	340854 FRAME PULSE + MAGNETOMETER
                              [ATTACH]27521[ATTACH]27527[/ATTACH][/ATTACH][ATTACH]27523[/ATTACH][ATTACH]27524[/ATTACH][ATTACH]27525[/ATTACH][ATTACH]27526[/ATTACH]
                              sure!?
                                samo jedna istina postoi _ u lazi su kratke noge ! Click image for larger version
Name:	FRAME PI 1.jpg
                                yes sure ! coil 50cm - gold ring 3g detected at 60cm .
