Hi all
I have built silver sabre plus and it go but there are same problem .
I built a DD 20cm in diameter coil and and i mach it at 10KHz, i have on Tx 9 9.5 volt and on rx i can go around 20-30 mv, the Tx and Rx are equal in form and number of turns so i presume that there isnt difference on which are tx and rx.
Each coil have schield and one estreme of the winding is put on shield and other is free so i have a shielded cable with 3 wire tx,rx and ground.
When i put wire on pcb in a order , in disc, i can heard a copper coin at 22-25cm in air and i have a little discrimination power but if i reverse wire Rx- Tx i cant have any signal from copper coin never from a 1Kg hammer at 1-2 cm and never fron a pcb 10x15 but a can heard a little allumium coin at 15 cm.
In all metal there are no difference and i can heard a copper coin at raffli 22 cm ,is not important in which order tx and rx are put.
What about?
It seem that coil have a phase degree and one time i add phase degree of coil whit degree from circuit and in the other case i subtract it.
May be this an explanation ? and how i can solve problem or how can built a different coil like concentric or coaxxial?
This is may first motion and i have learn a lot on motion machine and filter, i like this unit and i will happy it go at better.
Any help is appreciate
Thanks in advant
Massimo
What about?
Thanks in advant
Massimo
