help with surf pi kit no sound
i got 11.48 volts from 8 aa batts going in i get 11.41 volts at the speaker the regulator first leg 11.48 middle leg 1.41 third leg 11.43 (r12 r13 r14 ) all have 0 volts ?
Unfortunately that's the reality.Originally posted by alcartraz View Postthats not helping much i do not have access to a scope why do things never go straight forward ive double checked all components all in the right place all soldered it seams like iam getting transmit but not recive the delay dont do anything volume only works right at the end and tune dont do anything so its a major fail !!! any ideas ????
Without a scope you are going to find this extremely difficult to debug, and clearly you are already finding this a frustrating experience.
Start from the beginning:
Do the power supply voltages measure OK?
has anyone got voltages from various points around the board so i could compare ???????
You cannot just guess what's wrong and hope to find the fault that way. You must logically debug the problem, starting with the power supply, then the transmitter, and moving along the receiver stages before finally checking the audio circuit. If you don't own an oscilloscope, then I strongly suggest that you borrow one from a friend. Otherwise you will find this a very frustrating experience.
tryed the resistor no joy no sound unless i get coil near hed phone leads ?
iam geting a very quiet tone when i put the coil near buzzer or head phones and the speaker wires
just built the kit powered uo set offset to 0volts no sound but by accident if i touch the regulator i can hear a faint tone any help would be good thanksTags: None
