The CHANCE is a microprocessor controlled detector but the source code for it is not available from it's author
CHANCE PI CIRCUIT DIAGRAM NEEDED
Originally posted by sido View PostWas unable to set any parameters....Even lowering the sensitivity had no effect.
Will try winding me own choke to see if any difference.
I kept on getting a constant buzz/pulsing noise every couple of half seconds not from the speaker output but the coil itself and it is the 0.8.4 software from memory.
Will revive this project considering some people have some positive results and hopefully a latest programmed chip is available from Silverdog to try.
I am confident that it is not Electronic component fault related.
I did reduce as much EMI in surronding workbench so that can be eliminated.
Thankyou,
Regards Sid
When you get your CHANCE upgraded you will still find that there will be some much reduced 'chatter' in some situations due the explanations contained in the paper below:
If you have not already read this it gives an excellent description of the PI detector in operation and it's vulnerabilities as well as those of the VLF detectors.
Dan
Thanks Dan.Originally posted by baum7154 View PostWhen you get your CHANCE upgraded you will still find that there will be some much reduced 'chatter' in some situations due the explanations contained in the paper below:
Dan
I have not tried the detector away from my home EMI infested area.
Random pulsing may be due to powerlines and other local interference being injected .
When i get a chance I will take detector away from the City and try it in a reduced EMI country area.
Here is Australia we have 240 Volts 50 Hz in our homes as apposed to America 110 Volts at 60 Hz.
Could be our powerline frequency of 50 Hz causing my Chance to pulse in a constant sequence and wiping out any controls of the detector.
Another major source of Interference we have here is the Pay Tv cable network mounted on our same Electricity Power Poles outside our homes above ground
Adds alot of Interefernce to the HF Radio spectrum also.
Regards Sid
Yes, in my basement shop my detector will not operate properly with my old 32" CRT TV turned on in the room. I also always turn off all flourescent lights.Originally posted by sido View PostThanks Dan.
Regards Sid
Probably the biggest improvement you will see will be from the V1.2.1 software upgrade. I remember my detector frequently beeping with the old 0.8.4 software. When you have the new software installed try to get your damping resistance adjusted to allow the lowest possible Guard Interval setting of '10'. This may not be possible if the coil is not 'fast' enough, but minimizing the Guard Interval operating point will be beneficial.
Good luck,
Dan
The download that you seek is on this site, titled "1.2.1" dated 18/08/2011:Originally posted by reza vir View Post[ATTACH]26198[/ATTACH]
please upload program for ic micro avr?
You can then load up your ATMEGA chip.
i have just ordered a cheap atmega8 usb programmer from ebay china....can i just use the plug on the end of the programmer cable to fit directly into the x2 port on the chance pcb....will it be configured correctly with the programming pins of the atmega8 on the pcb ????
