yes thats good on a surf
help with a coil build
So i get part of my question answered. However i'm interested where i can burn the FET or damage the detector? Which are the critical values in terms of induction and resistance Minimum/Maximum values of both?Originally posted by Waikiki_Sweep View PostYou can use coil calculator to predict your inductance like for single wire.
Real inductance may be a little different depending how coil tight.
But difference 10-20% in inductance may be tolerated.
I have heard that Surf PI works from 230 mH to even 400 mH.
Thanks.
Mosfet is the only part of detector that could sustain damage if it sees too low of a resistance (short) or too high an inductance (high ring back voltage exceeding fets specs) from the coil.
Should not be a problem unless below about .4 ohms or above 1.8mh (1.8 milli henry = 1800 uh).230-400mH is a typo!!!!I have heard that Surf PI works from 230 mH to even 400 mH.
