Is there any way?
  • Is there any way?
    Hello
    is there any way to successfully locate 10-20kgs of any metal in depth of 6-8 meter? does EPE ERM able to locate it?
    If you touch those "any metal" with EPE ERM sensor, then yes.
      Check this out: www.geotech1.com/forums/showthread.php?20758
        Hi Dear WM6,
        I thank you for taking time out to answer my question. I am sure that you are really busy and I appreciate you taking the time to respond personally to me
        It sounds very good for me If EPE ERM can really locate them (may be gold, may be iron), because my ERM almost finished!
        Thank you again.
          Thank you for your response to my inquiry. I appreciate the information you have provided me with and I appreciate the prompt reply.
          Thank you again
            Hi wubian
            Earth Resistivity meters can detect bigger (large) conductive deposits in soil only.
            Not something like cube 10x10cm of gold (about 20kg of gold) at > 6 meters of depth.
            And target should be approximatelly between test electrodes, not 8m away (deeper) from level of electrodes.
            You understand my first reply wrong, sorry.
            Otherwise, EPE ERM is great project and you will have a lot of joy using it.
              Hi Dear WM6,
              I thank you for taking time out to answer my question, I really appreciate your willingness to assist.
              does a PI with 2M x 2M coil can locate it? you know, here there is a farm that may contain more that 20kgs of gold. but if actually there is any treasure, it is in depth of 6 meter.
              I thought 20kg of gold is much more bigger than 10x10cm , something like 50 x 50 x 5 cm cube
              Thank you again,
                Dear wubian,
                if we talk about cube then all sides of those cube are equal.
                So 50x50x50cm cube, if it is out of gold, weight about 2500kg and yes 10x10x10cm gold cube weight about 20kg.
                No way to locate 10cm sides gold cube wit 2x2m PI coil at depth 6-8m, except if those gold are rolled into sheets of about 2x2m.
                Deeper than two meters in soil, sweet dream area is beginning. Enjoy your dream and be real.
                  Dear WM6,
                  Thank you so much, I am sure that you are really busy and I appreciate you taking the time to respond personally to me. I wish there was a way to locate it, may be sometimes later when technology has been grown to upper level! may be...
                  Thank you again my Dear friend,
                    Originally posted by wubian View Post
                    Dear WM6,
                    Why do you think they would Bury a gold bar at 6 to 8 METERS Deep?
                    Have you Ever tried to dig Even One Meter Deep?
                      Hi Dear Chemele,
                      yes I dig sometimes up to 3 meters,
                      they don't buried "a" gold bar there, this is bigger than a chest, in other word this is at least something like a 60 x 40 x 50 cm regular wooden box. I thought this may height 10-20kgs but when WM6 said that 10kgs of gold are a 10 x 10 x 10 cm cube size, I think this is more than 50-80kgs, have you any Idea?
                      somebody in the past years checked there with something like Examiner and he said something like what I said.
                        If you mean the RangerTell Examiner, then forget it. There's nothing there. :examine
                          Hi Dear Qiaozhi,
                          I thank you for taking time out to answer my question. this is what I pointed to: click please something very similar to ERM and this is the reason whay I'm trying to finish ERM.
                            Hi Dear Qiaozhi,
                            OK - it's a Geo Examiner resistivity/magnetometer system, and not the swinging-arm RT Examiner nonsense, so at least you're in with a chance. Do you have any 3D plots of the site?
                              Hi Dear Qiaozhi,
                              unfortunately who came to test the farm didn't give any 3D plote
                              have you any Idea about how to locate it?
