PIC12F675 VLF
  • americano
    hello all good. I wonder do with the coil for vlf PIC12F675 will be grateful
    presents American
  • Qiaozhi
    Originally posted by americano View Post
    gotaria de sabre quali E o diametro da bobina EO fio Quantas Voltas de fio
  • americano
  • 6666
    Hi bernte_one
    Thank you for the files, much appreciated
    I will order a 12f675 and try and get it working,
    cheers
    6666
  • bernte_one
    look attachment
    picmd.rar
  • bernte_one
    hello Mr. Melbourne
    sure, i will ad all infos for contruction including hex. file and sprint layout files (for others the pdf b/w printout).
    it is not necessary to translate your words into german
    since i started to read here i could re-activate my english
    was not able to to invest more time in this project because i had to finish my differential mag. for 2014 hunting season
    but i promise all of my hobby work is free for forum and i share all i can but only if it works
    so most things will last some time
    if i forget some details here and there i trust on you that you will remind me
  • 6666
    bernte_one
    I have see your youtube video
    Could you please post a link to the software for this project.
    Is there any more construction information located anywhere on the net ?
    thank you
    I am trying a google translation, I hope it translates ok
    bernte_one
    Könnten Sie bitte einen Link auf die Software für dieses Projekt.
    Gibt es noch mehr Bau-Informationen überall im Netz befinden?
    danke
  • Qiaozhi
    Not bad at all for such a simple device. From where you get .hex file for PIC, is there any website related to this project? Maybe basic for detector, but looks like very good starting point for decent pinpointer probe.
    The problem with this design is going to be a lack of ground balance capability. It will work fine in an air test, but bringing the coil close to ground will kill the sensitivity to non-ferrous targets, unless you can keep the coil parallel (and a constant distance from) the ground.
  • 6666
    I wonder if a full wave rectifier in the RX would make any difference .
    Could you please tell us your coil specs thanks.
  • Tepco
    had time to made a video
    i hope to get some comments
    think there ist some space for improvements
    it is very basic but it fits to most beginners (in electronic and metal detecting) because it is so easy
    good night
  • ivconic
    "...btw has anybody some suggestions to pump more power to the tx coil..."
    Lower R3 and rise R4. It will affect power a bit, not much but a bit.
    Try to experiment with R7 too, lower it.
    Q1 can be some higher gain, maybe?
    And that's about all what you can try with present setup.
    I am interested in the design but not in that version.
    I prefer simpler version with one coil, to serve me as ppointer only.
    Has anybody made it as pp? Any video?
  • bernte_one
    good night
  • bernte_one
    hello
    i have mounted all components and made first test
    and must says yes it works
    easy to adjust
    balancing tx rx coils is very easy made by tone indication
    or measuring induced voltage on rx
    i have changed the resistor 39k to a pot with 100k for more gain
    the detector hhas following functions
    s2 for setting the threshold barrier also jused as a pinpointer if you get closer to obejct press s2 button and the new barrier it set more down
    s1 on off switch should be combined with a reset pushbutton (disconnector)
    pot 100k for gain(sens) adjust
    all works fine with a small enclosrue and a single 9v block
    not depth but i sure i will find some points for improvements
    if i calculated right with the frequency it works in the common 1/ 1,2 freqeuncy shift tx/rx as i know it from tesoro projects here but around 6khz area
    kind regards
  • Tepco
    It is not BFO but FM, well, similar, original schematic on this thread is not classic VLF but balanced coil off-resonance detector. All about best utilization of PIC.
  • Eddy71
    Look Waikiki_Sveep ​​scheme. There is shown a transmitter and a detector . In "KidFM" is only a LC oscillator. This BFO.
