I thought that maybe better I will put this here. So, after playing with pcb a bit, my Troy X3 is not reacting to metal. After plugging original coil, when I start it, it makes one longer beep (normally is one short) and there is no reaction to metal. Pinpoint button also not working, battery check works ok. I checked all the wires coming from pcb to the plug and looks like all wires are ok. I'm 90% sure I have not done accidental shorts on the pcb and 99% sure no mechanical damage to any of the components. Any ideas what could cause the problem? Thanks
Greg
Greg
I just soldered and de-soldered wires where the plug is on the pcb (first your picture shows that area).
