Hello, I wished carried out an audio connection without wire for my metal detector. I thus chose 2 modules from aurel: rxfmaudio and txfmaudio, I thus carried out 2 assemblies as on this site:
that functions rather well only I did not have enough power at exit in the helmet I thus modified some value of components on the receiver. I have thus to modify the condenser of exit in series with high the speakers I put one at it 100 uf instead of the 220 nf envisaged the sound is really more intense and a little more serious and I have to modify the resistance of 22 K which is at the entrance of the aop by one 2.2 KB. As I did not have aop TLC272 I replaced it by a NE5532 I thus have a his nickel on the other hand there or I have small problems I have a breath in the loudspeaker. and more I assemble volume plus this breath is present. somebody could you it help me to solve this problem since it is necessary to completely changing the stage of exit which appears me to be the source of the problem. In addition on another site I saw that on the level of the stage of exit it was not a aop used but one filled up audio of type LM386, therefore are what it is necessary that I entirely remake the assembly with this amplifier or then are what I can replace the aop by 2 transistors in darlington to see whether this breath attenuates.
