I have a Cen-Tech Hand Held Metal Detector #97245 that I use as a pin-pointer, but the Sensitivity setting has to be re-set too often.
I also have a Velleman K7102 Metal Detector Kit and plan to build the circuit board and then morph it into a pin-pointer with plastic case and pin-pointer tube. Admittedly, you can't expect too much from these "cheapie" units, but I'm wondering if there is a fix for the "wandering" Sensitivity setting.
Maybe the re-tuning is necessary as I move to different areas of the Park where ground mineralization type and/or saturation has changed. Do you think this is possible ?
Could the problem be amended or ameliorated by adding some kind of electronic component to the circuit ?
Thanks in advance for any help you can give.
ToddB66
ToddB66
It's apparent that you have/are working hard to figure out the pin-pointer circuits, all the while accepting critique with good humor while sharing your creative brilliance in electronics with us.
