this is my first post, so I would like to talk about me and my problem
I'm Carlos (mellao), from Spain, and I'm a little noob in this metal detectors world
I bought a surf pi 1.2 from silverdogs and I build it, and check the components a lot of times and it seems to be OK.
I did a coil with a enamelled wire 0.5mm, with 23 turns and 17cm of diameter.
I adjusted the offset on pin 6 of NE55 to have 0v.
So the problem was....:
I have response when moving the potentiometers, but, coil only detect medium objects (knife, scissors) maximum at 7cm, or small objects (coins) nearest to the coil.
This does not detect gold rings, even I pass through the coil, only beeps if I touch the coil with the ring.
I was looking for this problem in this forum but I doesn't get anything clear...
Anyone knows what could be the problem?
Thanks for your time!!
