You can now get a freq generator module off ebay for less than $10. What if you took one and build a magnetic loop around 3 feet in diameter and built a amp to feed it in the 10 watt range at say 1.8 mhz or the resonate freq of gold.
This is easily doable and you could mount it on a tripod and make it very portable.
Then what if you built a receiving antenna, enclosed it in a faraday cage with a 2 inch opening (maybe a 2 inch piece of copper pipe) to allow signal in, that could be hand held and very directional. Could you scan the ground for pieces of gold a distance around the loop for the reflections?
How far do you think it might detect small pieces of gold? How long before the FCC shows up
Just asking.
Just asking.
I got old brain cells you know. To much RF in the past cooked it! I worked on television transmitters. Some were so leaky that the florescent lights in the building lit up, even with the switch off.
