I was just contemplating how to reduce noise etc in a highly sensitive detector circuit and of course power supply noise is a big factor.
Does anyone know if the GPZ 7000/SDC2300 uses a split battery supply? As its a proprietary design and not the standard battery type, it would be easy to use this system and eliminate some regulator noise from the circuit.
I know split battery supplies have been discussed here before but if weight, packaging and recharging are not an issue, would there be an advantage?
