KTS PULS AR II and III or PULSE STAR II PRO
    Thank you Orbit on you comment
    Do you have experiences with another PI MD
      Please tell and solve your problems to or with KTS personally, Orbit!
      I really doubt this is bad quality or even not useable P.I. detectors.
      This is a professional working company if you believe it or not.
      btw. nonmotion detectors also need alot reset if the ground is problematic
      and it also depends on the search speed and how good someone can
      move the coil always exactly at the same distance over the ground.
      And when I look to those guys how unprofessional they used the Lorenz at Oak-Island
      I can imagine that alot other persons also have big problems or just bad results with P.I.
      And tragac, now you hear again that using PI might not be that great as you may think.
        If the problem " truth" withdraw word !And not compare Lorenz and Pulsar !
          Orbit do you mean Lorenz is far better than Pulsar
            Lorenz is very good detector I tried and Lorenz and Pulsar and Pulse Star 2 pro and Puls Star 2 for example Puls Star 2 is better of Puls Star 2 pro which has a copy of and on that basis I I worked Tomb Raider 2 Lorenz has some features more such as recording for me the best Lorenz and Pulse Star 2 older model no pro .But everyone has their own opinion and I respect that all the best .
              Can you tell me more about difference between pulse star II and pro
              is it still manufactured old model do you know price and where to buy
              is it only produced by http://www.tb-electronic.de/prodinfo/ps2/infops2e.htm
              can you please answer on questions and give comments on this tread about PI
              What is the best P.I. overall and for big treasure hoards?KTS;PULSE STAR;VANDAL PULSE3;DELTA PULSE3S
              thank you in advance
                best pulse detectors from Germany is Lorenz or Ebinger for professionel use
                for midrange class and advanced Hobby detectorist KTS and TB
                something exotic but most modern seem the new line from Pulsdetektor owner Diethelm Neyka (pulsdetektor.biz)
                good luck
                  bernte_one thank you on your answer
                  can you please answer PI MD questions on
                  http://www.geotech1.com/forums/showt...-DELTA-PULSE3S
                  because I have strarted new tread with name about PI on this way probably can collect more opinions and answers .....
                  Which models from Ebinger ,you think it best for hoard searching and similar purposes from KTS probably you mean on PULS AR III and from TB on PULSE STAR II
                  do you know something for TB for previous model and new one pulse star II advantage/disadvantage....
                  is it following link for http://www.proton-elektronik.de/ for Diethelm Neyka ,please give me correct link
                    Orbit, don't tell lies, because the truth is that I have not compared Lorenz with Pulsar or KTS
                    but the not good enough usage of some people and to what doubtful results they may come.
                    And there are alot people who "swear" on this or that P.I. detector, even some models from Bulgaria
                    or Greece. Just because this technology is so old and simple that even alot start to built their own ones -
                    this forum is full of such projects, too.
                    And tragac, you even can buy some easy to put together homebrew P.I. kits for just 20% of the usual price.
                    Connect the finished and working PCB with some battery, install everything in a housing and built your own coil
                    pretty simple and you're ready to go - or better to said to test how good P.I. works for you or not ....
                    If you wanna have the most expensive profi PI's of course you can spent 5000 bucks or more -
                    but I doubt you will do this as a rookie to this whole stuff.
                    Anyway, the whole PI discussion can continue for you from now on in the new opened thread.
                      Who this is a model pi detectors ? At issue is company KTS !Click image for larger version
ID:	344879Was it a watered epoxy resin ? Whether it this model ? https://www.youtube.com/watch?v=_Mc-NUxf_C0
                        Thanx for the link. As you can see from the tests: the devices from KTS are working very well.
                        The soil looks pretty loamy or mineralized, but the holes have alot air inside.
                        For real good tests after inserting the test object the hole should be filled up.
Name:	PS AR 3.JPG
                            Orbit has the pcb
                            sprint layout?
                              who has schematic of pulse ar? orbit dont want to share infos?
                                DEAR FRIENDS:
                                PLEASE SEND SCHEMATIC AND PCB FILE LAY FOR PULSE STAR II PRO AND SEARCH COIL DISCRIPTION.TO [email protected]
